!!!!!!!SPEEDOMETER DEAD!!!!!!!!
Old Dec 22, 2002
torqen2k1's Avatar
torqen2k1 is an unknown quantity at this point
HELP on Kamikaze header!!!
just installed my kamikaze header, and after extending the wires, the check engine light went on and after driving around 5 miles my battery light came on and on my gauges the volts dropped from 14-12. I looked at my speedo and it just dropped to zero and stayed like that. Also my air2fuel guage was reading really really rich. Need help bad [IMG]i/expressions/face-icon-small-frown.gif[/IMG] [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
EDIT: now my speedometer is only dead. my battery light is on. Its still at 12 volts instead of 14. what could be wrong?
Old Dec 22, 2002
CarbonFly's Avatar
Isn't there some module that you have to buy?
its something that tricks the sensor into thinking that nothing has changed......i forget what it is called.
EDIT: Found it
Comptech ESM (Electronic Signal Modifier)
Comptech ESM (Electronic Signal Modifier) This adjustable switch is commonly used to keep the ECU from seeing a boost signal from the MAP Sensor when you are adding a turbo or supercharger to a car that didn't come that way. Can be used on any car or sensor up to 3.4 volts. Easy4 wire hookup. Comes adjusted for Honda/Acura MAP voltage signal, but is easily adjusted to needs of other cars. Universal fit. Not subject to CARB certification.
Old Dec 22, 2002
XxPloSiv2k1Lx's Avatar
XxPloSiv2k1Lx is an unknown quantity at this point
thats never heard of...maybe you should check your wires again...your check engine lights and all you other lights shouldnt have poped up soo fast... i think that thing is called a MAP sensor or something like that i forgot also!!!
Old Dec 22, 2002
KeNsHiN's Avatar
LEVA
damm dude that sounds bad[IMG]i/expressions/face-icon-small-frown.gif[/IMG] i will reasearch for you
Old Dec 22, 2002
CarbonFly's Avatar
Quote
[hr]Originally posted by: KeNsHiN
damm dude that sounds bad[IMG]i/expressions/face-icon-small-frown.gif[/IMG] i wikll reasearch for you [hr]
That's the biggest joke i've ever heard. Name onethread where you helped someone when you weren't repeating something htat someone had already posted ahead of you.
You're the damn black sheep of the BoB.
Old Dec 22, 2002
KeNsHiN's Avatar
LEVA
ok then am out[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Old Dec 22, 2002
torqen2k1's Avatar
Quote
ok then am out[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG][hr]
thanks flyriceracer02
Old Dec 22, 2002
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Doesn't that sound like a problem with the alternator?
Old Dec 22, 2002
GhettoCivic's Avatar
GhettoCivic is an unknown quantity at this point
Quote
[hr]Originally posted by: FlyRiceRacer02
EDIT: Found it
Comptech ESM (Electronic Signal Modifier) This adjustable switch is commonly used to keep the ECU from seeing a boost signal from the MAP Sensor when you are adding a turbo or supercharger to a car that didn't come that way. Can be used on any car or sensor up to 3.4 volts. Easy4 wire hookup. Comes adjusted for Honda/Acura MAP voltage signal, but is easily adjusted to needs of other cars. Universal fit. Not subject to CARB certification. [hr]
I don't know, I know there was something from Diablo Autosports? that you had to buy to keep the check engine light from coming on. Isn't that Comptech thing only work when you are running boost though? I don't know, it just sounds like that from the description.
Old Dec 22, 2002
torqen2k1's Avatar
Quote
[hr]Originally posted by: Smokie2k2LX
Doesn't that sound like a problem with the alternator?[hr]
no i already had a whining problem with the alternator and honda replaced it. thanks anyways [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 22, 2002
Boosted2k2's Avatar
go reset the ECU again... it sounds like an odd problem.
Old Dec 22, 2002
torqen2k1's Avatar
well, i already reset the ecu. i had the battery unhooked all night. is that the right way to do it? [IMG]i/expressions/face-icon-small-smile.gif[/IMG] if i'm supposed to disconnect fuses, which ones?
Old Dec 22, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
The thing from diablo motorsports is the o2 simulator. You only need that if you dont want your check engine light coming on.
Old Dec 22, 2002
torqen2k1's Avatar
Is their a way to reset the speedometer? or somethin like that/[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 22, 2002
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
Yes you want to pull the 15a fuse labeled F.I. ECU. That will reset just the ECU and not your radio settings, etc etc. The product from diablo is an o2 simulator. Most people put these in with the HP header w/hi flo cat. It will trick the ECU into thinking that the 2nd o2 sensor is getting a proper reading with the cat. CEL should come on after your 2nd long trip. Mine came on after my second long trip and i drove it for about 3 days with the light on and it went off. (I was going to get the simulator the day it shut off) so i saved myself like 60 bux...if it is a CEL for the o2 sensor, i would just let it ride for a few days and it will go out...save yourself a few bucks....but by what you are describing it doesn't sound like a CEL for your o2 would cause the spedo to drop and your alternator to produce less voltage...Check the code that your ECU is throwing, that should give you a good idea where to start.
Old Dec 22, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: xblkcivicx
Check the code that your ECU is throwing, that should give you a good idea where to start.[hr]
You can't in our cars unless you have an OBDII scanner.
To reset the engine ECU pull the blue 15 Amp fuse. It's number 6 in the fuse box in the engine bay. Look on the back side of the fuse box lid to see which one it is.
##x
X marks the spot, it's one of the smaller fuses. There's a fuse puller in the fuse box. Find it.
Um, it sounds like the sensor wires aren't hooked up properly. That's why it was so rich. Re-check the sensor wiring. Solder it! I don't know... Then try it again.
Old Dec 22, 2002
So when you buy a Kamikaze header, do you need to buy an O2 Simulator or do you need to buy that Comptech thing? Will your check engine light come on forever?
Old Dec 22, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
Shedding light on the voltage.... Honda alternators have a voltage regulator that operated between 12 and 14 volts. The system only operates at 14 volts if it needs it (i.e. battery charging, headlights on...) but most of the time the alternator operates at 12 volts....
Old Dec 22, 2002
xblkcivicx's Avatar
Where can you get a scanner and how much do they run for? I imagine it's damn expensive...If you can even get one.
Old Dec 22, 2002
2001civ's Avatar
2001civ is an unknown quantity at this point
Yeah the ECU scannar is pretty costly, A perfomance shop could order one for you. I wouldn't spend the money on one unless you work on hondas a lot.
Did you get the car to start? If not do what they said check the wires around header, there is on just the right of the header that is connected to the alternator when it comes lose the car will start but the alternator won't charge the engine so you will probably only be able to start it once or twice. the connection is under a rubber cap or sorts. check that.
Old Dec 22, 2002
blue2k1civic's Avatar
blue2k1civic is an unknown quantity at this point
he's probably not gonna be online today, but he just called me and told me now his volts guage is down to around 8.5-8 and his oil temp, rpm, speedo, and fuel gauges all dont work. also his mileage was reset and its all zero. [IMG]i/expressions/face-icon-small-confused.gif[/IMG] he's goin to honda tommorow hopefully.
Old Dec 22, 2002
torqen2k1's Avatar
On the exhaust senser their are two white cables does it matter which white cable goes to a white cable.
Old Dec 22, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: torqen2k1
On the exhaust senser their are two white cables does it matter which white cable goes to a white cable.[hr]
Maybe. If it doesn't work one way, then reverse it and try it out.
Old Dec 22, 2002
torqen2k1's Avatar
Quote
also their is a grey and a black cable i hooked them up black/black grey/grey.
and the air/fuel gauge gets hooked up to the black cable right?
Old Dec 22, 2002
torqen2k1's Avatar
Well now I put my stock header on and hooked up the exhaust sensers to the header and is ready rich! So the cable for the air/fuel gauge is supposed to be hooked up to the black cable right?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 22, 2002
torqen2k1's Avatar
Well Im sellin my parts off my car because I have no job and have to pay for monthly payments also I own my mom $1k and also Im plannin on sellin my car by the summer because I dont like paying monthly payments also every time I work on my car at home my mom bitche$ at me cause "cause I have a new car and Im gona void the warrenty and ect" so Im not goin to have to worry about car payments and warrenty and my mom bitchen at me all the time. I am goin to sell all my parts that I bought for my car: Thermal R&D header-back exhaust fully stainless steel, used for like two months, my Kamikaze ceramic header used for like 10 miles, my AEM blue cold air intake used 4 months with a new K&N air filter very clean, my Ground Control coilovers brand new in box never used, my DC sports strut tower bar (chrome) almost new used 2 weeks perfect condtion, DC sports rear lower tie bar 4 months old, and my DC sports shift adapter perfect condition,
for $1,500 OBO
Crazygrlinak
Oct 8, 2015 05:06 PM
260000milesgoal
Sep 25, 2015 07:41 PM
Skunkone
Sep 24, 2015 04:38 PM
jerry38
Sep 20, 2015 08:38 AM
MamaBear2015
Sep 15, 2015 09:35 PM
