painting top piece of door panel - need your help
Super Member
I'de like to thank everyone who's helped me get this far. I took the center radio, ac trim piece apart, and the door trim pieces, and will paint tommorow. What I want to know is how hard is it to take the top piece of the door panel off? I've seen the diy on removing the door panel but can anyone elaborate on this? If I remove the screws can I just start yanking it off? Or is their a certain technique? Once off, does the top piece seperate from the rest of the panel? I have gone this far and might as well do it all while I've got everything apart. If anyone can give their input I'de appreciate it. The piece I'm talking about is about 6" wide and pretty much runs along the top of the door, and sweeps up near the back of the door, just beyond the door locks. BTW, my car's a 2-door if that makes any difference.
Thanks,
Justin
Thanks,
Justin
No, that peice doesn't come off seperately. To get it off, just fololow the DIY and then mask what you dont want to paint and make sure to mask off the top peice of the panel that runs along the window (I guess it's some kind of weatherstripping - just can't remeber now).
its not a saw piece, its riveted in with plastic rivets. each of the three pieces and also the map pocket are built in this fashion. it also means youll need a heat gun or a glue gun to get it back togerher in one piece again......
timpan
May 18, 2015 07:06 AM
MamaBear2015
May 3, 2015 02:17 PM
BabyLX
Nov 8, 2001 09:25 AM
