our abs system....is it different?
Old Dec 3, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
well, last night we got a few inches of snow, so i put on my hat, gloves and went for a spirited drive in the extremly large parking lot we have here on campus. i was having tons of fun getting sideways, drifting and doing 180s...but i noticed something rather odd....it seems that our abs system monitors wheel lockup, even when NOT braking, unless it monitors use of the e-brake!?
upon pulling the e-brake to induce sideways action, i could clearly hear the abs monitor going ape-$hit trying to keep the wheels from locking, and as the car began to get sideways i could seem to feel the car trying to keep the front wheels from locking....after droping the e-brake back down it seemed as if the abs system continued to operate for a few moments
when i owned my 91 integra gs (which had abs) i dont recall the abs system trying to prevent wheel lockup when pulling the e-brake..
does our abs system constantly monitor wheel-lockup? or does it consider the e-brake as brake input...?
mark
Old Dec 3, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
i think it was the e-brake...we have (ex anyways) 4 wheel abs and if you are locking up the rears with the e-brake then it will pulsate
Old Dec 3, 2002
solar's Avatar
solar is an unknown quantity at this point
The ABS is just doing its job, it senced that the rear wheels weren't turning but the fronts were so it tried to stop the rear wheels from locking up. I don't think that Honda engineers had in mind that people would be using thier parking brake for donuts.
Old Dec 3, 2002
mwwhonda's Avatar
my point is that abs is normally only supposed to work under braking conditions, and most abs system DO NOT monitor the use of the e-brake
a system like traction control constantly monitors wheel lock up and spin, and would compare front to rear wheel speeds, not a system like abs.....abs system should only individually monitor wheel lockup under BRAKING conditions.
mark
Old Dec 3, 2002
mwwhonda's Avatar
i dont consider the use of the e-brake a "braking situation"...only pushing of the brake pedal, like in my integra
i know how i am going to figure this out
i will unhook the wire from the e-brake and see if it still monitors the lockup when i lock the rear wheels, that will determine if the abs system CONSTANTLY monitors wheel lockup, or just under breakin situations
mark
Old Dec 3, 2002
solar's Avatar
If the ABS ingages without using the brakes than I guess its some type of traction control but I dought it. I would assume that when the parking brake is applied that the computer sences the rear brake pads are engaged when the car is moving and tries to stop the lock up. Seems to me though its kind of a waste of time to find out why the ABS works that way with the parking brake, because it wasn't designed to work under those conditions. I wouldn't wory about it and have some more fun doing donuts
Old Dec 3, 2002
mwwhonda's Avatar
i only worry about it because "if your pump was going nuts, you might foam the fluid, which can wreck the modulator if done enough"
again, stupidity of the 7th civic....i wish i had bought a gsr [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
mark
this car cant be driven how i want to drive it...garbage
[IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Dec 3, 2002
bobbyd's Avatar
I think there are sensors at the wheels that tells the ecu whether or not the wheels are spinning or not spinning...not spinning=locked brakes therefore causeing the abs to kick on.
Old Dec 3, 2002
MadWheel's Avatar
Premium Boosted Member
seeing this is making me upset, i dont know, i make videos with my buddies and it clearly shows my rear locked up, maybe our drums are just a lil too weak or something, do a rear drum to disc conversion and i bet all your probs will go away (i didn't do it on mine but i guess i just pull it really hard) -lata
Old Dec 3, 2002
mwwhonda's Avatar
my rears lock, that is not the problem....read closely next time
Old Dec 3, 2002
MadWheel's Avatar
Quote
[hr]Originally posted by: mwwhonda
my rears lock, that is not the problem....read closely next time [hr]
yeah i just cought that, my bad man, i haven't really noticed it though, i'll have to pay close attention this sunday night lol
Old Dec 3, 2002
Diemos's Avatar
Diemos is an unknown quantity at this point
huh I dont have any problems pulling 180s.... my ABS doesnt kick in...
Old Dec 3, 2002
MadWheel's Avatar
Quote
[hr]Originally posted by: Diemos
huh I dont have any problems pulling 180s.... my ABS doesnt kick in...[hr]
LOL - I made the same mistake, his brakes lock up man read it a couple times
Old Dec 4, 2002
mwwhonda's Avatar
madwheel...no biggie...
"its all good!"
h4ldol
Apr 24, 2017 08:16 PM
viperGTS
Jul 27, 2015 08:40 PM
Kyrian
Jun 26, 2015 11:48 AM
turboslug
Oct 15, 2002 09:49 PM
JBlazeVA
May 9, 2002 12:38 AM
