HP 4-1 Header w/ OEM Header Heat Shield
I would like to know will the OEM header heat shield (oem header cover) will fit over the HP Header. Since the HP 4-1 Header is illegal, i would like to mount the header cover onto the header to decieve the police officers.
Quote
[hr]Originally posted by: cvc2k2
just 2 bolts is enough. i just want it covered.
the 3rd one can be left off.[hr]
Escaped Convict
although it isn't what u were going for...
u should consider header wraps... they work like heatshields....
keeps the heat within the pipes so exhaust fumes exit faster and smoother.. and keeps the heat outta the engine bay.
Quote
yes it is illegal.. if you search. the HP 4-1 header is designed for off-road use only. i want to use the whole setup HP Header setup but have it concieled.[hr]
ThatGuy913
Nov 9, 2015 06:31 AM
jdh022764
18
Nov 3, 2015 06:44 AM
i didnt read your post carefully. i would rather use the whole HP 4-1 Header setup.. or none at all.
