engine didn't start. . .
Old Dec 11, 2002
ProDigy's Avatar
GT-S BoY
ProDigy is an unknown quantity at this point
All right. . i thought i posted this yesterday but i guess not. N/E ways, it was the middle of the afternoon, around 2:30 pm. . . I just got out of school and went straight to my car. As i put the key in and turned the ignition, the car just kept trying to start. So after about 4 seconds i stopped. . . i waited about a couple more seconds and decided to try agian. . .THIS TIME i still didn't start and i was holding the ignition a little longer. . . sooo i waited about 5 minutes and pushed my clutch down, AGAIN, and tried starting. . this time it finally worked. . . N/E one know what happened?? Is there something wrong with my ignition or the engine??? Has this happen to anyone?
Old Dec 11, 2002
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
Happen to me before no biggie
Only happend once though
but if it keeps happening bring it back to the dealership
BTW how many miles you got on your car???
Old Dec 11, 2002
ProDigy's Avatar
GT-S BoY
i got almost 15,000. . im in need to take it to the dealership for some alignment and rotating. . . oil change and what not. .
Old Dec 11, 2002
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
If you here it clicking and it is like russian roulette when you put the key in, it is most likely the starter...time to take to dealer and get a
new one
Old Dec 11, 2002
CivicGoh's Avatar
CivicGoh is an unknown quantity at this point
Actually that has happend to me quite a few times. I've had my car for about 6 months now and i guess about 2 times a month it will not start right away. I have just over 4500 km on my car too so its pretty new still. So i took my car in to the dealership and they had it checked but they said they couldn't find a problem. So im not sure.... i heard our cars have really bad altinators so maybe that might be the problem
Old Dec 11, 2002
Grey's Avatar
DIY King
Um, I hope it's not as simple as this... You have to depress the clutch all the way to start our cars.
I always depress the clutch all the way and depress the gas pedal a little bit. Then I let go of the gas pedal and start the car. Then I let go of the clutch (making sure the car is in neutral).
Old Dec 11, 2002
BlueRevs's Avatar
BlueRevs is an unknown quantity at this point
Um, do you have a car alarm? IF you dont then this will be a waist of a post but oh well. I have a Viper alarm, and only since i got it does it do this. Everytime you turn your car on do you listen for the fuel pump to kick in before you make the engine turn over? IF not, then the next time you get into your car turn your key to accesories, you will here a sound of a little motor pumping the fuel to your engine before it starts. This maybe connected to my alarm or it may not be, everytime i call about it i get the run around from my dealership saying it is the alarm and then i call the place that put in my alarm and they say they don't connect anything to the fuel pump........ Anyway, yeah when my fuel pump doesn't kick in, i will get out have a cigarette and then get back in and damn thing works again. I just have patients with it now.
Old Dec 11, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
battery. our batteries suck..i just put an optima in mine. my battery died twice within a month so it was time to go. it also made a clicking sound one time but that was not the starter going bad.
Old Dec 11, 2002
Nacho's Avatar
Nacho is an unknown quantity at this point
To bad your not in so cal... I think my ride can keep up wit cha?!
Maybe some time we can meet up? hehehehe
Old Dec 11, 2002
XxJDMCivicxX's Avatar
Are batteries are that bad? I'm at ~26,000km anyone else have problems with the battery around then?
Old Dec 11, 2002
LuZi0n's Avatar
LuZi0n is an unknown quantity at this point
Yeah, happens to me about once or twice a month as well. All i do is take the key out the ignition and depress the clutch and the put it back in and it starts right up. It doesnt really bother me that much, but the fact that the car only has 5000 miles, kinda makes me wonder.
Old Dec 12, 2002
ProDigy's Avatar
GT-S BoY
yeahs nacho. . i do live in so cal. .
Old Dec 14, 2002
bobbyd's Avatar
Quote
[hr]Originally posted by: XxJDMCivicxX
Are batteries are that bad? I'm at ~26,000km anyone else have problems with the battery around then?[hr]
Bad? He!! mine went bad with only 11,000 miles on it. Warranty will cover it but I wanted an Optima anyway.
Old Dec 14, 2002
Mbow's Avatar
I think the non-starting issues are stemming from the immobilizer chip in the key. Mine has done it once while my wife was trying to start it. She said the green key kept blinking which means the ecu isn't recognizing the key for whatever reason. You simply remove the key and reinsert and it should be fine.
Also, you will here the starter trying to turn the engine over. The immoblizer cuts the fuel, it doesn't do anything to any other part.
So, the moral of the story: Take key out and put back in. Take note if key keeps blinking or blinks a couple times and goes out.
Old Dec 15, 2002
OMega's Avatar
OMega is an unknown quantity at this point
I've go the same problem, car is a hard start cold or worm sometimes. Its been like that since I've owned it. In my lude all you gotta do is tap its on. Dosen't sound good looks like honda is starting to enter the land of electrical problems
Old Dec 15, 2002
Mbow's Avatar
Quote
[hr]Originally posted by: OMega
I've go the same problem, car is a hard start cold or worm sometimes. Its been like that since I've owned it. In my lude all you gotta do is tap its on. Dosen't sound good looks like honda is starting to enter the land of electrical problems[hr]
I f-in hope not. That's the worst type of problem to have.
sharp66
31
Jun 12, 2022 08:45 AM
Allecr3
May 22, 2015 01:24 PM
CivicVoz
Apr 16, 2015 08:07 PM
smmahan
Apr 15, 2015 08:17 PM
supercivic01
South
Nov 30, 2001 11:27 AM
