Indiglo gauge wiring
Old Dec 17, 2002
LiKEaFeRiO's Avatar
I have indiglo (not reverse) gauges that light up blue and green with a dimmer.
My controls looks exactly like JAJE's.
I was skimming through the DIY and other results from my search and I didn't find an answer.
My gauges have 2 connectors, one for each side of the gauge faces.
My wiring has 4 connectors that all fit into any of the 2 connectors from the guage faces.
Is my wiring wrong? Someone help me.
Thanks
Old Dec 17, 2002
snoopbag's Avatar
snoopbag is an unknown quantity at this point
You can use any of the connectors to connect to your gauges. I'm not sure why they put four on there but I used the two shorter ones and mine worked fine. If you got any more ?'s PM me.
Old Dec 17, 2002
4Saris's Avatar
4Saris is an unknown quantity at this point
There are some gauges that require all 4 connectors to be connected in order to light up the entire cluster. Rather than making a connector for each gauge kit, they just made one, it lowers production costs. Any two should work, just tape off the other two. I would suggest that you use the longest two just in case a short occurs, you can always use the ones that you have not used. It really doesn't matter though.
BootyDo
Jun 21, 2016 03:45 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
JUNITO
Jul 9, 2015 08:36 PM
robbie374
Jul 7, 2015 02:56 AM
manicEL
Dec 10, 2001 06:33 PM
