PDA
View Full Version : Engine
Pages : 1 2 3 [4] 5 6
  1. Cooling system
  2. Power Steering Pump O Rings.
  3. EGR Bolts Stripped...
  4. Code p1361 tdc sensor 1 noise
  5. URGENT: Timing belt tensioner access port?
  6. Oil leak estimates
  7. Someone Help PLease Lol.
  8. Weird Bushing Found Under the Car On The Driveway.
  9. Motor mounts
  10. 2001 civic
  11. Valve/vibration.
  12. P0420 what can it be?
  13. What size is the manual shifter bolt?
  14. What is the purpose of the inspection plate on my 2004 Honda civic hybrid?
  15. d17a1 vtec d17a2
  16. P0135 and P0141 codes HELP!!
  17. 2001 Civic EX Bank 1, Sensor 1 location
  18. Machine shop did not clean cylinder head
  19. D17 oil pressure gauge
  20. 2004 Honda Civic Lx 1.7 P0100
  21. 02 Civic EX Vtec 5 speed manual P0336 HELP!!
  22. Civic is missing still
  23. Where is my engine leaking oil from?
  24. Oil leak and and miss fires
  25. fuel pressure regulator
  26. D14Z6 oil
  27. 4000rpm limiter
  28. Beck Arnely Head Gasket set?
  29. Engine leak I cant figure out
  30. 2005 honda civic special edition
  31. Missfires
  32. Broken Thermostat
  33. Missfire(Flashing CEL)
  34. Please help! Valve cover bolt snapped.
  35. 02 honda civic ex vtec mecanical help. Wont start
  36. 2005 civic lx D17a2 high idle
  37. Spuddering when I accelerate with more than 50% throttle
  38. What's going on with my engine?🤷🏽‍♂️
  39. D17A2 Complete Rebuild Questions
  40. Oil pan gasket or just hondabond?
  41. Engine shut down at 60 mph and will not start.
  42. '02 EX Coupe - Cylinder Head Issues
  43. What is this?
  44. Question about Oil Pump
  45. 125lb compression reading across all 4 cylinders
  46. 2004 Civic EX Sputter on Start Up - Idles Perfect
  47. 2005 civic hybrid O2 monitor not ready
  48. Mixing coolant/ heater weak when stopped
  49. Junkyard valve cover “melting”
  50. 02 civic ex auto cylinder 1 misfire "help needed"
  51. Mixing 3 new sparkplugs with 1 old?
  52. D17A1 - A2 Sharing Parts
  53. 2004 Civic EX with P2279 but runs/idles fine
  54. Engine dies at different times
  55. Timing belt confessions (and Advice needed)
  56. 2002 EX long exhaust pipe broke
  57. Engine dies suddenly after heating up
  58. Vibration coming through the dash and steering wheel at idle
  59. 05 civic valve cover hole
  60. Overfilled 1.7l with way too much oil like a dumbass
  61. Sluggish acceleration when AC is on
  62. Low oil pressure?
  63. How to replace the injectors in a 2002 1.6i?
  64. Valve cover thread
  65. Head gasket
  66. Fuel injectors 04 Honda Civic
  67. What gasket/seal is this?
  68. Timing belt
  69. engine swap
  70. Sparkplug broke inside
  71. Gas gauge heavily dropping/fluctuating
  72. Honda Civic electrical problem
  73. O2 sensor trouble
  74. Mystery hose.
  75. Newbie - 2002 Ex Coupe owner
  76. Persistent P0301 - flashing MIL - 2002 Civic EX
  77. Emissions codes
  78. Still getting squealing after drive belt change.
  79. Engine Mounts
  80. Cold start at -30C
  81. Burning Oil
  82. Huge Knocking/Rattle Loud Noise After Timing Belt Change
  83. P1259 Code
  84. 2004 Civic EX D17A2 Oil Pump Removal
  85. Can I swap 01 vtec cylinder head onto a 05 non vtec
  86. VTEC solenoid 2001 civic
  87. Oil Leak
  88. Multiple Cylinder misfire
  89. Replaced TDC sensor, still in limp mode
  90. Piston rings installation order
  91. Engine Oil Leak - 2005 Honda Civic EX
  92. 2003 EX- runs great but rapidly losing oil
  93. New Oil leak, oil over filled
  94. '02 LX Power Loss?
  95. 4th time oil pan gasket replace this year
  96. 2005 Honda Civic EX - Code P2646
  97. Vtec oil leak
  98. Muffler help
  99. 2 unidentifiable bolts
  100. Throttle Positioning Sensor/ Throttle Body
  101. D17A2 died, how to diagnose troble
  102. 04 Civic D17A2 oil in spark plug well
  103. Oil Pan Leaks With New Gasket and Pan
  104. Maximum warpage on a 2004 civic ex 1.7 vetec engine block
  105. 04 civic 1.7 rev issue
  106. Need advice on head gasket brand
  107. Locating an oil leak suggestions pls
  108. 2005 Civic EX - Cold start problems then fine
  109. Car stalled repeatedly, now everything is magically fine...worried
  110. Coolant Burping Procedure...
  111. Losing all my oil.
  112. Part number for Crank Front Seal?
  113. Which radiator cap???
  114. D17A2 engine oil problem - help wanted please.
  115. what the heck is this?
  116. General compression (D17A1)
  117. Should I be able to turn camshaft by hand?
  118. 2004 honda civic ex temp gauge and rpm not working
  119. Evap system
  120. 2002 Civic 1.7 Broken Water Pump bolts - screwed?
  121. Vtec oil pressure bypass for a JDM swap
  122. Vibration inside engine?
  123. What do you call to this part?
  124. Oil pump o ring & pan gasket, any else needs replacing?
  125. Oxygen sensor problems
  126. Which Amazon Head Gasket Kit to Buy? D17a2
  127. Where you buy exhaust valve retainer clips
  128. Head gasket type
  129. 04 ex auto multiple misfires on 2,3, and 4.
  130. Camshaft won't turn, broke timing belt
  131. Honda Civic 2005 lx
  132. 2001 Honda Civic oil leak
  133. Cylinder misfire
  134. Oil/ possibly coolant leak. Head gasket?
  135. 2004 Honda Civic -2 doors- 1.7 engine. Piston Removal w/o removing engine
  136. New oil pan leaking 2005 LX help!
  137. Broken Exhaust
  138. 2001 Civic engine problems
  139. P1128 Code
  140. Power Steering Pump Squealing Noise
  141. P0139 - Rear O2 Sensor keeps failing
  142. Removing rounded nuts
  143. 04 Civic 1.7 p0339
  144. Code P0341 on 2003 Civic EX
  145. 02 Honda Civic
  146. Honda civic lx 01
  147. 2002 LX 02 wire connections
  148. Cam seal plug
  149. ‘01 Civic LX Manual Alternator Belt problems
  150. engine vibrates and knocking sounds then stall after timing belt changed
  151. 2001 Honda Civic ex leak
  152. 02 non vtec odd thumping after engine replacement
  153. 2004 Civic, 1.7 Engine. Valve job
  154. 03 civic lx
  155. The oil leak that just won't go away
  156. Vtec solenoid
  157. EX alluminum oil pan fit an LX ?
  158. Engine flush
  159. vtec question
  160. Rattling after letting out throttle at high rpm
  161. 2005 HONDA CIVIC 1.7L Primary Heated Oxygen Sensor (Primary HO2S)
  162. MIL and Immobilizer problems
  163. Odd part with jdm
  164. D17A1 Oil Pressure Problems
  165. Leaking oil
  166. vendor recommendation/head gasket cost?
  167. Wont rev past 3k, sputters and stalls.
  168. Strange A/C Noise
  169. Timing belt whining after replacement
  170. P0497 Purge Valve Bolt
  171. No o-ring on PS fluid supply line??
  172. Buddy massively over filled engine, blown head gasket?
  173. After driving for an exact time/distance car loses power
  174. 2002 Hoda Civic EX 1.7 No V-tec Bogs on acceleration stalls runs rough
  175. 05 lx, oil pan broken stud, third gasket already
  176. 2005 lx oil pan gasket 4 loose washers position
  177. 2001 Civic LX 1.7l NEED ADVICE ON ALTERNATOR/WATERPUMP QUESTION
  178. 2003 Civic LX 1.7L Idle (no CEL)
  179. 05 civic lx 1.7l non vtec will not rev past 4000
  180. Power loss when accelerating
  181. Camshaft sensor failure
  182. Engine Block Damage Repairable or Not??? See pics on thread
  183. P1362, P1361 Help!!!
  184. EVAP issues
  185. Honda Civic 2005 dx
  186. Thick white smoke from tailpipe and loss of power after putting 2 quarts of oil
  187. Civic 2005 P302 Code
  188. Check Engine Light/Thermostat Code despite entire system being serviced
  189. Oil leak. Need some help. 2004 civic coupe
  190. Stripped Tensioner Bolt
  191. replace one or four ignition coil?
  192. P0420 code after tune-up work
  193. Radiator neck upper broke
  194. Engine Light Codes P0138 & P1457
  195. What should support the air filter housing?
  196. Engine stutter at first throttle, in gear only...
  197. Crankshaft seal and reseal plate $141.00
  198. 2002 Civic Ex Will not Accelerate
  199. Power
  200. Radiator fan connector possibly melted w/ video
  201. Oil leak after transmission replacement
  202. Oil Pump O-Ring - 2002 Civic EX Sedan
  203. Engine almost stalls for no reason... any ideas?
  204. P1361
  205. 2004 Honda VTECH Problem
  206. Intake manifold
  207. Alternator adjustment bolt just fell out.
  208. Runs fine but can randomly run terrible
  209. Failed Emissions Test Lambda
  210. Headgasket
  211. 02 Civic LX P0128 P1298 P1361 P0132
  212. Check engine light p0401
  213. Replaced the head gasket after overheating and dying. Low compression in 2 and 3
  214. 01-05 O2 Sensors (Air Fuel)
  215. 01 civic Vtec malfunction
  216. Thermostat question
  217. 02 civic cat conv & exhaust manifold
  218. damage timing belt broke, worth fixing?
  219. Blue Smoke on Start-up
  220. part fell off when opening valve cover
  221. Dry carbon fouled plug
  222. 04 civic VP wont crank after alternator replacement
  223. Cylinder head
  224. Civic hybrid starts then dies
  225. Any guides to replace head gasket without doing the timing belt?
  226. D17a2 Rebuild. For life, not for power.
  227. Honda Civic Ex 2002 oil leaking problem
  228. Engine swaps.
  229. Looking for a recommendation on engine mounts
  230. Issue after using seafoam in civic
  231. Jumped Timing?
  232. 2002 civic dx sedan 1.7L burning oil
  233. Oil Leak Repair(s)
  234. Low oil pressure at idle
  235. D17A2 - Burning Oil
  236. 2005 SiG P0134/P0139
  237. Head Gasket blew and Massive Oil leak
  238. Murphys law with a touch of WTF
  239. Civic EX troubles
  240. How to troubleshoot a P0497 and P1457 EVAP code?
  241. Transmission cooler line
  242. Oil leak from around exhaust tubes?
  243. Strange Cooling Fan Sound
  244. 1.3 hybrid head replaced
  245. P0135 2004 Honda Civic DX
  246. Car jerking when cruising at all speeds
  247. head gasket replacement project
  248. Head is off, Where is the failure? PICS
  249. 2001 Civic LX head Gasket Reinstall testing during assembly
  250. Crankshaft Position Sensor
