Head Gasket blew and Massive Oil leak
Old May 17, 2019
Bosco19's Avatar
Bosco19 is an unknown quantity at this point
Is it common for the head gasket to cause mass seepage ? My 2001 Civic LX started leaking tons of oil at the same time as the head gasket blew and started pushing coolant out of the reservoir.
Old May 17, 2019
Colin42's Avatar
Re: Head Gasket blew and Massive Oil leak
None of that seepage looks fresh
Old May 17, 2019
Slumpertcivic's Avatar
Definitely would change the oil pump oring while you have most of the parts off anyways.
Old May 21, 2019
noquacks's Avatar
noquacks is an unknown quantity at this point
Start with washing it all down well, then observe again for fresh ooozing/seepage. I just went through a similar ordeal, although, my source may be different (it was the solenoid gaskets).
Old May 21, 2019
Bosco19's Avatar
I just pulled off the breather cover, literally. The bottom bolt was so rusted that the head was almost gone. Breather cover was so rusted I just twisted the bolt out along with it. Pretty sure that at least one of the leaks.
Thanks !
bachands
27
May 2, 2021 06:18 AM
Boxxy
Nov 2, 2016 11:37 PM
medicpg
Jan 12, 2015 07:47 PM
BigLeg
Jan 11, 2013 05:14 PM
dailydriverEX
Nov 12, 2011 08:54 AM
