View Full Version : Engine
- missing part
- 148lbs crankpulley bolt specs 2001 civic lx
- 2001 civic hunting idle after timing belt change
- Problem finding an air filter
- Cracked ex. manifold, code p0441
- D17a2 vtec
- Pitting in head
- My Squealing 2003 Civic Is Making Me Loony!
- 2004 d17a1 lacking power
- Vertical cylinder scratches, and color changing head gasket
- Sucker for punishment.
- Are the oil holes in the Crank supposed to always be aligned with the bearings?
- Loss of power after restarting when car is driven several miles
- Engine not revving over 4k rpm and loss of power sometimes
- Thoughts and opinions on spark plug condition
- 2005 Civic - Intermittent P0344 and P0340 - Bad camshaft pos sensor?
- D17A1 ring end gap out of spec / oem black main bearing alternate?
- Car cranks but has no power
- My 05civic lx is far from dead. I can believe this. Lol
- 02 civic stalls
- Sensor Code P0135 D17A
- P0497 and P1457 intermittent
- Is p1457 realistically ever the the fuel cap?
- 2002 Civic 2.0 - belt squeal and smoke
- What can be the reason behind a major mileage drop after an engine rebuild?
- Exhaust Solution & Question
- Gas pedal sticking when trying to accelerate
- Why did I go through 3/4 of a tank or fuel in 2 days of spirited driving?
- Check Engine light and Car Switch off on the road
- Sudden loss of economy
- No Compression Cylinder 3 After Head Gasket Replacement [solved]
- limp mode: how can i disable it
- Compression readings
- Oil dipstick showing different levels on each side
- Rust/caked on carbon on header gasket area.
- Belt Tensioner
- I money shifted from 3rd to 2nd going 110kmh. Engine is misfiring.
- Cable or wire not really sure
- Oil leak help
- It's not the Crank Positioning Sensor! [solved]
- Cam Bore Oring
- car won't gain rpm's fuel cell, d16Y8 intake
- is drill the only option - air filter bolt stripped
- need help identifying oil leak
- Head gasket replacement
- EVAP sensor
- oxygen sensor STILL gives P0134
- Car just quits at low speed. Idle? Something worse?
- Engine starts once when cold, then nothing [solved]
- Rattle from engine bay on decel
- PLEASE HELP. Code P0141 with limp mode. NEED my car back
- Engine misfire on a 2003 Civic EX Coupe
- P1342 [solved]
- Pipe to manifold gasket/seal doesn't fit
- replacement exhaust manifold catalytic converter came with no heat shielding
- Cylinder Head question
- Timing belt job questions (sohc)
- Civic Ep1 which engines fit straight in?
- 2001 civic lx. ac compressor is making screeching noise [solved]
- Torque Specification
- Strange crack found on cylinder head cover
- Engine in Safety Mode...AGAIN
- Car wants to stall when cranking it
- P0135
- Need advice 2003 LX ECU
- On third gear 4,5k 5k rpm vtec fault
- 2004 civic knocking noise
- 2005 EX civic D17a2, P2646 w severe driver side oil leak
- Bank 1 Sensor 1 fault
- 5 spd m/t
- Connecting rod cap
- 2005 Honda D17A1 overheating intermittently
- Burning smell 2003 EX Sedan (230k miles)
- I have 3 bolts extra.
- P0420, p01457(?) Codes
- Oil in EGR intake port on the Head, problem?
- Can I reuse a pretty much new Head Gasket (I know it sounds)
- no check engine, can't pass emiisions
- Possible bad ECU?
- Squeaking sound
- This soooo much fun
- Check engine light
- 03 hybrid - thermostat replacement
- left over spacer - 2001 HX [solved]
- need source engine [Please help is really not descriptive]
- bad catalyc converter 2003 civic lx
- 1361 going limp please help me
- R & R PCV valve, '03 Hybrid?
- Plastic PCV valve on gen7 2001?
- 04 Civic EX p0135 Reoccuring, Rough start, Swap ECU Questions
- Parts Question: Transmisson to Engine Bolt, RAD reserve Tank Hose.
- 2001 honda civic dx 1.7
- 2002 CIVIC LX P0131 after engine heats up
- Crank Sensor?
- Won't start unless holding throttle. Low rpm missfire. [solved]
- Stripped the Engine Mount bolt??? Engine mount completely torn up?
- Oil leak?
- Fuel pump problem
- Does anyone know what this is?
- O2 Sensors
- Head gasket torque / sequence D16V1
- Help! I can’t find timing marks....
- Timing Belt question
- Rpm ratios
- Engine Swap
- Civic help please my only car to work
- Oil leaking?
- p1259 Freeze Frame Data
- Vtec Solenoid adapters
- Can anyone reccomend an engine exchange company? 05 Civic
- Werid noises and a stall. Fun
- 2005 Civic LX revs up when I give a normal amount of gas
- Issues with Y8 mani ON the D17
- Where is this oil leak coming from?
- Strange noise near engine/belts
- Oil Leak right drivers side under filter box
- P0117 / p1361 / p1298
- My 2003 Civic has a squealing belt and it's making me crazy
- Rpm issues
- Removing old IAT sensor do I just force it out?
- Spark Plugs
- Oil Leak(s)
- P1505 error code
- Help if there any ways to swap 3stage vtec solenoid into jdm vtec without replacing E
- Rebuilding d17a1 for stock conditions
- Help!
- eu8 d16v1 valve clearance specs?
- 2003 Civic EX 5speed oil leak
- D17a2 massive cooilant mixing with oil
- Gaskets for Catalytic convertor
- Engine air filter housing problem
- Car turn over but wont start
- Did I buy a knock-off sensor? - solved
- AC doesn't cold after Heater been active
- Replaced rear main seal and I think its leaking again. Shit.
- 2005 Honda Civic Cat/ exhaust Bracket/ spring mount
- VVT solenoid leak
- Heating core
- Honing
- I got a P0131 code on my civic 03
- Fuel leakage
- Sudden, severe oil leak - poss head gasket? The01 Civic
- I have a p1259 code honda civic 2003 ex
- Piston rings
- Key stuck in ignition
- 2003 Ex Coupe (D17a2) P0340 then P0341
- Exhaust leak, bad mount, transmission issue?
- Cylinder honed
- Hose clamp for Power Steering?
- Thread specs?
- Replacing timing belt... anything I should NOT do?
- Rocker Arm Assembly VTEC piston missing
- 01 Honda Civic LX Help!
- How-To: Fitting atop engine blew out and now leaks gas... HELP
- Car running hot after shifting funny
- 2003 Si EP3 idle moving up and down
- Help!! [Engine stopped, Camshaft sensor? - note by moderator for easier problem ID]
- Valve adjustment
- Squealing belt
- Help
- Piston rings
- Car randomly came to a halt then restarted 30 minutes later
- P0505!!!!!
- 01 civic limp mode
- 18 Year Old Timing Belt
- P1456 code common causes
- ‘01 Civic LX hesitates at 4K rpm’s
- 2001 Honda Civic precious owner problems
- 01 civic techs out at 4000 rpms
- Error Code: P0135 A/F or O2?
- 1.7L Engine Rebuild [solved]
- 04 Civic ex stalls after 3rpm
- Wire harness and ecu question
- Please help
- Oil drips
- Side Engine Mount
- Horrible knock
- Engine light came back on
- Exhaust
- Only starts when it is hot outside
- P0139 2005 civic
- Map sensor location
- 2001 Honda Civic LX
- P1259 code, VTEC solenoid
- Reuse timing belt?
- Cam and rocker arm assembly issue
- Vtec leaves.
- Exhaust Crack
- 2001 Honda Civic 4cyl
- Honda civic 2003 ex stutter upon acceleration
- Knocking noise from engine at idle
- Failed VTEC system TDC and OVERHEAT
- P1129 and P0507
- 2002 Civic LX Fuel Pressure Test
- V-tec
- cooling fan frustration
- 2002 Honda Civic LX w/ D17A (JDM) engine (P0171)
- 2002 Honda Civic Crankshaft Position Sensor Misfiring
- Code P0340 Engine overheat then stalls
- Squealing noise pulling away
- 2002 Civic LX no start
- VTEC Solenoid not Plugged in?? Questions - HELP.
- Oil filter
- Car stalling at idle and misfire
- 03 Honda Civic LX manual P0303 code
- EVAP problem
- What ECU do I have in my ‘01 Civic Lx manual?
- Timing Belt marks off by 16th of an Inch and I'm going nuts.
- 03 civic LX 1.7 head gasket replacement.
- HELP! Cylinder misfires and need to drive 2,000 miles with no other options
- Misfires
- 03 ex D17YA2 head gasket job, hi idle surging
- 2005 EX 1.7 VTEC won't start after TB, WP HG changed out..
- Getting a P0108. Cleaned MAP sensor and it's still in limp mode
- Mysterious blue cable.
- 05 civic timing belt replacement
- Low power when engine warms up.
- Weird screw/bolts on MAP sensor on throttle body... need to remove
- 2004 civic manual trans wont rev over 3000 rpms
- 03 civic lx with spun rod bearing... HELP!!!
- Gas smell, and Voila!
- Warped block?
- 2002 civic 1.7 limp mode
- Block deformation d17
- 2003 Civic EX runs for 15 seconds, then stumbles and dies
- Bad fuel Reading
- Having trouble reassembling throttle body on my 2004
- re-torque head bolts with timing belt on?
- Messed up timing during head gasket job, how do I reset the timing?
- LIMP MODE - 2001 Civic LX
- 05 civic dies when i take my foot off the accelerator.
- Looking for a solution to p1457
- Flexible Joint Bolt Torque Spec
- Squeak on startup
- Fuel Pump Sock/Suction Filter
- 2003 Civic EX loss of power while driving
- 4,000 rpm rev limit 2001 Honda Civic dx 5spd
- 01 Civic LX 1.7L - Loss of Power at Highway Speeds
- Won't rev above 3000
- radiator cooling fans
- P0300, P0303 and P0304
- Upper alternator bracket
- shes a pain
- Crank sensor engine light on...help
- 05 LX SE - puzzling oil pan leak - solved
- Bent rear main seal
- Valve adjustment
- new muffler suggestions
- 2003 ex with a d17a1 in it
- 3500 rpm acts like hitting rev limiter
