2002 Honda Civic Crankshaft Position Sensor Misfiring
Old Aug 6, 2020
Hannah Ott's Avatar
Hannah Ott is an unknown quantity at this point
Exclamation 2002 Honda Civic Crankshaft Position Sensor Misfiring
In August of 2019 I took my car to an automatic where he replaced my crankshaft position sensor. Everything was running smoothly until March of this year when my car started having acceleration issues (not as intense as it was in August) and then would have intermittent delay start up until it finally would not start at all. During that time of trying to figure out what the issue was, I replaced the camshaft position sensor. I then had it towed to a mechanic in which I provided the off market crankshaft position sensor and they installed it. Today, August 6th (only 4 months later) as I was driving along my check engine light came on so I decided to take it to Advance Auto to have them test it. When I came to a stop (thankfully at the entrance of a neighborhood) my car stalled and all the lights on the dashboard appeared. I then turned off the car and let it sit for a few minutes. I turned the car back on and was able to drive it to the auto shop and had them test it. The OBD2 tester said that it was the crankshaft position sensor.
My question is, why would the crankshaft position sensor go bad so quickly? (This is the 3rd time I would have to replace it in a year and a half.) Could it be the wiring that is causing the issue and not the actual sensor? If it is the sensor and not the wiring, could it be because I kept getting off market sensors and not the actual Honda sensor?
Please help!
Old Aug 6, 2020
FRSam's Avatar
Click Here
Re: 2002 Honda Civic Crankshaft Position Sensor Misfiring
I'm almost certain this is your problem. Honda's have never taken well to aftermarket components. I suspect you'll have no issues once you switch to one from Honda. You'll be looking to spend in the area of $100 for just the sensor.
A member came across "the deal of a lifetime" when he found $15 Honda sensors on eBay. DO NOT DO THIS. Either go to a Honda dealership or find a reputable website that sells genuine Honda parts. I'd be shocked if you find any for less than the $100-ish range.
Old Aug 6, 2020
Hannah Ott's Avatar
I was afraid this was the answer. The thing is, I know this is probably the only option that I have in order to fix it, however I have already put in a total of about $1500 into maintenance on this car in the past year and a half. I contacted my local Honda dealer and the price for the part is a little over $200. Since I don't have the equipment needed to actually change the part, I will have to take it to a mechanic once again which will end up costing me another $350 which will total to about $550. Do you think it is worth it? How long do you think this piece will last? I don't want to spend all this money again to turn around and have to either junk this car or have this issue arise in the next few months to a year.
Old Aug 6, 2020
FRSam's Avatar
Click Here
I bought my civic from my neighbour in 2015. He had the cam position sensor replaced with the timing belt in 2008. It hasn’t been replaced since. Assuming that’s actually your issue, a genuine Honda part will last the rest of the life of the car.
Old Aug 6, 2020
$125 at Majestic Honda, P/N 37500-PLC-015, about $10 shipping, at least to Vegas it's about $10 for shipping
List price is $185, I can see dealerships charging $200+ for the part. If you ask nicely, local dealer may price match online price, as long as it's a genuine honda parts dealer. One of the local dealerships here in Vegas will price match online price+shipping and get it pretty much next day if it's not in stock. Doesn't hurt to ask. Worst they can say is no
edit: story time. I went to one of my local Honda dealers, and I asked about price matching Majestic Honda's price. Dude straight up went, "ah crap.. you know about Majestic... let me see what I can do," and went to get the parts manager. Parts manager was able to get me within $10 of the Majestic Honda price+shipping, which was good enough for me since they readily had it in stock
Old Aug 7, 2020
Any reputable mechanic shop offers a warranty on the work, and the parts sourced for their work.
What are the terms of that warranty?
Who obtained the crank sensor?
Old Aug 8, 2020
leok99's Avatar
leok99 is an unknown quantity at this point
Use rockauto for part#(denso/ngk) and shop around for best price.
For your car, NTK EH0214 or DENSO 1962001 will fit and it's about $60.
ksplitt99
Aug 11, 2019 06:24 AM
honda.lioness
Sep 17, 2017 04:19 PM
contevo
May 8, 2015 03:49 PM
BiggieCivvie
Jan 24, 2011 05:00 PM
SOHC
Buy, Sell, & Trade - Archive
May 6, 2010 08:37 PM
