Car stalls while driving
Old Jul 19, 2019
ksplitt99's Avatar
ksplitt99 is an unknown quantity at this point
Have 1999 Civic DX, 1.6L automatic, 207K. Am selling car. Recently car has begun to stall while driving; simply shuts off. Was intermittent, now more frequent. I put in N, start up & go or it takes a few starts, then OK.
CEL has been on long before this problem with only code PO135, the 02 heat sensor. Speed Sensor/Throttle Position Sensor checked & OK. My trusted mechanic does not think the ECU [expensive], says could be distributor or Camshaft Positioning Sensor, [also expensive], but then we’re off spending money chasing problems which may not fix the issue. I have a feeling about the Camshaft Sensor though..eh, what do I know.
What do YOU guys think? Thanks for all help.
Old Jul 19, 2019
old97civic's Avatar
old97civic is an unknown quantity at this point
Re: Car stalls while driving
P0135 is for the primary O2 sensor, did you change it? The primary sensor is the one the computer uses to calculate and inject the right amount of fuel. If it's toast the car will run rough at best and stall at worst.
Old Aug 11, 2019
Strick's Avatar
Strick is an unknown quantity at this point
Interesting. Thanks. Another bit of info for my knowledge of Hondas.
tide55
Dec 19, 2013 11:37 PM
sekhonjatt
Jun 24, 2013 08:09 PM
BrickM
Sep 27, 2012 02:25 PM
BiggieCivvie
Jan 24, 2011 05:00 PM
SODJAZERO
Jun 18, 2005 07:41 PM
