2001 civic hunting idle after timing belt change
Old Jul 18, 2021
quartermilecame's Avatar
quartermilecame is an unknown quantity at this point
totally wasnt expecting this. did timing belt. sprayed throttle body with throttle body cleaner. tent change went fine but still going through posts like mine for hunting idle. so far nothing. going to assume i did something wrong but what??????? 215k miles
Old Jul 18, 2021
FRSam's Avatar
Click Here
Re: 2001 civic hunting idle after timing belt change
Any check engine lights?
Old Jul 18, 2021
just now got the engine light. trying to remember how to pull the codes. pin 4 and 9......just want to be sure Im doing it right.
Old Jul 18, 2021
FRSam's Avatar
Click Here
Use an OBD2 reader.
Old Jul 18, 2021
one long flash quickly followed by 4 short flashes over and over.......is that the iac valve?
Old Jul 18, 2021
unplug the valve and it goes to a very quick hunting idle. I thought it would stop hunting
Old Jul 18, 2021
FRSam's Avatar
Click Here
It sounds like you’re triggering SRS codes. If you don’t have an OBD2 reader, a parts store will read them for free.
Old Jul 18, 2021
going to go get a reader........also just came back from pull a part with 2 idle air control valves. swapped one in.......idle is not hunting now.. rev it up and let go and it will drop then rev to 1500 then drop down to normal idle. I used shitloads of throttle body cleaner on valve and throttle body. could that have damaged it or removed grease inside the valve causing it to fail or have oddball hunting idle issues?
Old Jul 18, 2021
did you try an idle re-learn procedure?
Bottom of the first post in this thread
https://www.civicforums.com/forums/3...e-posting.html
Old Jul 18, 2021
looked at original iac valve and sure enough its super clean...........and FROZEN. WOW! SHOT SOME WD 40 AND FREED IT UP.
Old Jul 18, 2021
The idle learn was next try after subbing in used iac valve which fixed hunting issue. I had a hunch that was it after I put a piece of cardboard over iac valve throttle body square hole mostly covered and it smoothed right out. Probably should do idle learn anyway. Btw for any of us that live in road salt infested states.....it sure helps to spray down the 3 phillips screws then beat on the heads of them before attempting removal. That saves on stripped screw heads.
Old Jul 18, 2021
Ok so idle learn is that simple. Then yes I did the idle learn by controlled accident. Cleared codes with battery disconnected then ran it over 10 minutes thinking the coolant needs to burp.
scout206
22
Oct 30, 2017 11:21 PM
Suchsloth
Apr 19, 2016 07:54 PM
Passed18
17
Mar 9, 2014 01:28 AM
yepitsme06
May 8, 2010 10:29 AM
shroomster
Oct 30, 2005 06:41 PM
