Crank sensor engine light on...help
Old May 28, 2020
brokercar's Avatar
brokercar is an unknown quantity at this point
I got a Honda Civic 2001 Lx
Crashed it last winter... done all sorts of things to fix it now.
For various reasons... i've had the timing belt on and off maybe more than a dozen times now....
Ive recently been getting the P0336 diagnostic code.
I just replaced the old sensor... which I had totally broken the bolt-hole on. I thought that would fix the issue.
---it didnt.
The timing MIGHT possibly be off.... but i just feel like its not. It is seemingly difficult to get the timing belt on if the cam sprocket isnt lined up.
When I start the car, it cranks for a little bit longer than is normal... but not that long.
It idles OK, but is a bit wavy perhaps.
Any input? I'm tired of taking this car apart....
Old May 28, 2020
FRSam's Avatar
Click Here
Re: Crank sensor engine light on...help
Did you cheap out on the sensor? Honda's don't take well to anything that isn't OEM.
Old May 28, 2020
Colin42's Avatar
This
Old May 28, 2020
brokercar's Avatar
Update:
So I tested the Crank Sensor.... took my voltmeter, grounded the black - and shoved the red down into the back of the plug on the Blue wire.
disconnected the ignition coils
then turned the crank by hand.
I got a reading of 5v on / 0.2v off with the sensor - which should mean the sensor is fine and works.
BUT NOW!!!!
When I go to start the car
It starts right up! No long cranking.
But then IMMEDIATELY dies.
I got a P0336 reading on the computer.
Reset it.
And dont get any reading now. No light, but I doubt the car is on long enough to get a reading. But then again, the computer shuts the engine down.
wtf.... did I totally off up the sensors wireing? I tried wiggling them around. Nothing.
no spark? I checked all the coils. Seemed ok.
damn.
Old May 28, 2020
brokercar's Avatar
Another update!
Turns out I can keep the car running if I give it some gas.
I kept it at 3k rpm for a bit, temp gauge went right up on the car!
the engine seemed to run ok.
started to smell funny
turned off the car. went for a look.
the exhaust manifold was RED hot!
lolz. fml.
I'm done for the day. back into it later.
Old May 28, 2020
Colin42's Avatar
Either timing is off or exhaust restriction
Old May 29, 2020
BrotatoChip's Avatar
Super Moderator
Timing isn't too difficult to check:
https://www.civicforums.com/forums/1...ne-timing.html
Old Jul 16, 2020
brokercar's Avatar
The saga continues...
-Still have the cheap Crank Sensor in there, but it checks out as good. I tested for 5v on/off when I hand turned the engine.
-The sensor plate seems to trigger the sensor good. I checked the plates interaction with the sensor.
TIMING: wtf. Like, it could be this, those damn marks on the cam sprocket are oriented not at right angles to the head. IDK. I got the straight edge out, I know that "up" is really like @ 350 degrees. You line the "horizontal" marks up with the plastic molding on the head? Thats what it seems like.
I've done the timing on this car several times prior - never had any issues.
Of course, every time I change the timing, the engine responds differently. But the P0336 still comes on. I disconnect the battery in-between things so the computer should be reset.
WHATELSE could this be? At this point, I just can't see it being the timing.
Old Jul 16, 2020
Super Moderator
Can you post pics of the timing marks? Yes "UP" isn't really straight up, you're using the lines on the side to line up to the top of the head anyways.
Also, did you check for an exhaust restriction as suggested above? See if it runs better with an O2 sensor or the header removed.
Old Jul 17, 2020
brokercar's Avatar
sorry, didnt get any pics.
OK so - I can't seem to get the timing right.
I line the marks up on the crank sensor plate thingy - I line up the marks on the cam sprocket.
I slip that belt on - If I ease the tension back on from the tensioner I'll keep the crank on her marks.
-so, I get all marks lined up proper (I'm certain of this), then I spin that bad-larry round twice counter-clockwise.
get that crank back on the mark....and BLAMO! The cam sprocket is SLIGHTLY too far clockwise. Closer to 360* the the cocked 355* its supposed to be. The marks on the sprocket put the wheel like half a tooth to far over.
Its off by a damn hair! This can't be right. Is this normal?? I don't think so. Is that enough to trip p0336??
I know my tensioner is a bit wonky, but I don't think it could be that??
The sensor plate has a little bit of play in it? A little.
I did have the camshaft out a while ago?
frigidity frig frig firigfffft
Old Jul 20, 2020
Super Moderator
Pics would still help. Try lining up the camshaft then looking at the crank marks. Is it off a full tooth? Crank spins twice as fast as the cam. If the crank is lined up and cam is off a half tooth that means with the cam lined up the crank would be off a full tooth.
There are timing marks on the engine side of the camshaft sprocket as well if that helps.
Old Sep 21, 2020
brokercar's Avatar
Hello folks-
Update.
After months of struggle and pain, she's running again!
Right before I got the code to go away I did TWO things - so hard sayin what the real solution was.
1) I cleaned the dirty battery terminals
2) I shelled out for the $80 OEM sensor, as opposed to the cheap aftermarket one.
Runs like a top.
Timing was always fine.
Thanks for the input.
Old Sep 21, 2020
FRSam's Avatar
Click Here
It was the sensor.
Old Sep 21, 2020
I'm putting money on the sensor, too. Glad you got it worked out
SilvySS
Mar 16, 2023 06:25 AM
1996
Feb 12, 2016 11:41 PM
Cabbio
Bolt-on Engine Performance
Aug 14, 2012 07:45 PM
meowadishi
Mar 4, 2011 08:19 PM
EG06KRS
Oct 9, 2007 01:55 PM
