Engine starts once when cold, then nothing [solved]
Old Apr 22, 2021
vboss5764's Avatar
vboss5764 is an unknown quantity at this point
I know the head gasket is leaking on this one, but not bad, but it has not had this problem until now. When cold it starts and runs with lower than normal power but its smooth, no missing, then once you shut it off and try to restart, even immediately after a cold start, it tries once like it wants to start but then nothing, just spins like no fire or no fuel, but cranking sounds normal. Tried starting fluid, nothing. Scanned it but no codes, I get a RPM sig of around 255 while cranking, No codes after driving it, while running live data all seems normal. 2003 Civic EX 1.7 auto IMMO is always working no issues.
Top Answer
Apr 22, 2021
vboss5764's Avatar
vboss5764
re: Engine starts once when cold, then nothing [solved]
I put on a new CTS and problem solved. These Honda don't take kindly to bad sensors. usually a bad sensor will maintain drivability.
Old Apr 22, 2021
mac25's Avatar
Dr Krieger of Modification
Do you have a live data scan of the temperature sensor? If they go bad they can mess up the fuel blend, while not throwing a CEL.
but test it first before replacing.
Old Apr 22, 2021
vboss5764's Avatar
lvfd9
Air Conditioning
May 31, 2020 09:19 AM
sruger
Nov 15, 2015 02:52 PM
gdm129
Jan 28, 2014 08:28 AM
eruffini
18
Jun 11, 2013 04:54 PM
