oxygen sensor STILL gives P0134
Old Apr 23, 2021
cycleboy506's Avatar
cycleboy506 is an unknown quantity at this point
On a 2005 Civic: The mechanic installed a new oxygen sensor in September 2020, which eliminated the following two codes:P0135 OBD-II: O2 Sensor Heater Circuit (Bank 1 Sensor 1)
P0134 OBD-II: O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
But every couple of months since then, I get the P0134 code again! Once, I *think* I solved it by shoving the sensor's connector harness more tightly into its socket.
Is this just a case of a loose connector harness, or something more serious?
Every time this happens, I use the OBD code reader to clear the code, but it keeps coming back. And the state inspection is due in two months
This is the O2 sensor I bought in September:
Amrxuts 234-9017 Upstream Sensor 1 Air Fuel Ratio Oxygen Sensor
for Honda 2004-2005 Civic EX Acura EL 1.7L l4 192400-1170 36531-PLR-003
Sold by: Shunmiao Auto Parts
The mechanic installed this as the Front O2 sensor, i.e. directly on the engine manifold. (The other O2 sensor is under the middle of the car, on the .. catalytic converter?)
Old Apr 23, 2021
FRSam's Avatar
Click Here
Re: oxygen sensor STILL gives P0134
Purchase an OEM sensor. Honda's don't take well to aftermarket crap. OEM will be Denso or NTK. Spend the money; it'll be close to $100 or it's fake.
Old Apr 24, 2021
Colin42's Avatar
You bought a cheap crappy sensor.
go buy the correct Denso one, and buy one that's at least $80 cheaper ones will be fake
Old Apr 24, 2021
It's the upstream sensor on an 04-05. It's gonna be more than $100. Likely gonna be closer to $300. Honda put in wideband AFR sensors for bank 1 starting in 2004 model years
Old Apr 24, 2021
Colin42's Avatar
My mistake, the real Denso I bought on Amazon for my 05 was around $150
Old Apr 24, 2021
Thanks all - I appreciate the advice. Sounds like I should just take it to the Honda dealership and let them install their own OEM part? (I'm sure they'll charge me several hundred dollars extra )
Or should I just buy a Denso from amazon and let my same mechanic install the Denso?
Is it possible to compare the specs of the Amrxut vs. Denso sensors? Is the Amrxut not wideband? How could I tell?
I see a Denso sensor on amazon now for $182 ("List Price $358.38"), and the one I bought (Amrxuts) was just $63. I wasn't trying to get a cheap part - I didn't know that Denso or NTK were better, or "OEM". It was trouble enough finding the correct model number.
Amazon Amazon
Old Apr 24, 2021
FRSam's Avatar
Click Here
Since you’re getting it replaced, I would let the mechanic/dealership get the part. They won’t warranty parts you bring in if it doesn’t fix it the problem.
Old Apr 24, 2021
Colin42's Avatar
It's a 5 min job, especially since it was just replaced.
You could buy the sensor from rockauto if you want to be more confident that you're getting a legit part.
Then buy an o2 sensor socket
MichaelEB
18
Jul 26, 2014 10:33 PM
tide55
Dec 19, 2013 11:37 PM
rbeatty
Dec 9, 2012 09:00 AM
BrickM
Sep 27, 2012 02:25 PM
ssamson1989
Apr 18, 2012 12:36 AM
