eu8 d16v1 valve clearance specs?
Re: eu8 d16v1 valve clearance specs?
Should be noted that you should adjust valve clearance when the engine is cold (<100F/37.78C if I recall correctly), and thus those specs.
I’d aim for the smaller number. If the smaller number fits snugly and the bigger number doesn’t go in at all, you’re in good shape.
So, 0.018 for intake and 0.023 for exhaust.
I have read somewhere that this in this kind of engine they get tighter over time. (I think you wrote an extra 0)
I did. The original numbers I posted apply.
If I were to recommend something else, get yourself a set of go-no-go feeler gauges. They make it so much easier.
Graeme.Crawley
Jun 4, 2011 12:18 AM
