Werid noises and a stall. Fun
Old Jan 18, 2021
Turtlekingmaste's Avatar
I eat crayons
Turtlekingmaste is an unknown quantity at this point
Car been acting werid all day. Got a 03 civic ex that was making subtle rattling noises all day. Didn't know what is wrong and still don't know. But it gets worse. Rattling noises sounds like a paper going into a fan at first. Then it gets worse. Sounds like a wire being spun around and hitting everything. Soon after it went from fan paper to wire tornado the car stalls and two lights come on immediately. Thc oil light and the battery light. Check engine did not come on and is still not on. Tried to crank and it turns over except the engine shakes and the wire tornado is worse. Not daring to start it again. Although it can run, tow guy drove it like 10 feet. Runs fine except for the massive rattle. It's home now and tow guy thinks it may be a belt that's in not good condition. Any advice on what it could be. It's sitting on the road rn and the latest I can check it is in the morning. As a side note, I check oil and it was fine. My headlights are on as it is night time so I am not sure why those lights came on. Please help!!!
Old Jan 18, 2021
Re: Werid noises and a stall. Fun
You will need to open the hood and check what is out of place.
You can do it, we can't.
All i see are letters in my screen
Old Jan 18, 2021
I eat crayons
Yup did that tonight. Everything looked fine. I'm just wondering what it could possibly be. What should I look for is what I'm asking, I'm not sure what it could be
Old Jan 18, 2021
FRSam's Avatar
Click Here
Try removing the tension from the belts and seeing if the noise stops. All-in, it should take a little over an hour.
It’ll be 2 belts if I recall correctly; AC/PS, and then alternator
Old Jan 18, 2021
I eat crayons
Both belts? I only recall 2 belts I can see. 3rd belt should be timing under the cover right?
Old Jan 18, 2021
FRSam's Avatar
Click Here
Yes, both meaning 2. It wouldn’t hurt to check the condition of your timing belt while you’re at it either. Just a few bolts holding the timing cover in place.
Old Jan 18, 2021
I eat crayons
Right in trippin. How loose should I loosen em to. Or should I remove the belts. I'll def check the timing belt.
Old Jan 18, 2021
FRSam's Avatar
Click Here
Loose to the point where the belts won’t rotate with the pulley. The alternator belt is a bit of a pain in the *** to attach so I usually just let it sit loosely on top.
Old Jan 19, 2021
I eat crayons
Right ok. Just making sure so I don't **** something up. You want me to loosen both belts and have it so that it won't turn. Then try to start the car. Wouldn't it not work cuz the serpentine belt won't move or sum.
Old Jan 19, 2021
FRSam's Avatar
Click Here
The timing belt runs the car, not the serpentine belt. It has no bearing on the car running, with the exception that the battery will eventually die and the car will subsequently shut off.
If you’re more comfortable with it, just take the belts off entirely.
Old Jan 19, 2021
I eat crayons
Took both belts off, still made the noise. It's more like a screeching noise. Any ideas?
Old Jan 19, 2021
FRSam's Avatar
Click Here
Could you post a video?
Could be a something like a seized pulley. Are they still rotating?
Old Jan 19, 2021
I eat crayons
Sorry for my lack of knowledge. The big one spins, but it sounds painful.
https://photos.app.goo.gl/baYNsJfvhENFhXoy5
Old Jan 19, 2021
I eat crayons
Oh if you are asking if each one spins. They all spin fine
Old Jan 19, 2021
well...
something got bent, or out of place, or loose.
Something moving is touch things it should not, or vibrations are making sheet metal squeaky against each pother.
If you can't find it visually now... Then it's likely hidden.
First suspect is timing belt, so you will need to remove the covers.
Old Jan 19, 2021
I eat crayons
It's getting late so I'll get the covers off tmmr. On the bright side I got some belts to replace the ones I took out. If something is bent. What's the possiblity it could be fixed.
Old Jan 19, 2021
find out what first
Old Jan 19, 2021
I eat crayons
Will do. Just asking some questions to learn about it. What could be bent? The valves? What else could be loose.
Old Jan 19, 2021
it does not sound like something internal to engine
Old Jan 19, 2021
FRSam's Avatar
Click Here
Next step would probably be to pull the crank pulley. You’ll need a holding tool for it which I suspect you won’t have. It’s like $10 on Amazon.
Old Jan 19, 2021
i would first pull of the cover to the timing belt - tension could be goner.
description of the noise could be a shredded timing belt also, flapping and hitting the cover
Old Jan 20, 2021
I eat crayons
I actually have the tool. I was looking at changing my timing belt for a while but got rlly busy. Ill get it off soon.
Old Jan 20, 2021
I eat crayons
Aw man. I spent all day on it. Timing belt is new. It's a new kit so new tensioner, water pump and belt. Previous owner changed it before we bought it. I didn't even get to use my kit. But the issue is not the timing. Mechanic neighbor came and looked at it and said timing was good. He thinks it may be transmission, as when I showed him the video he heard metal on metal. His advice is to remove the starter and see the condition of it's teeth. What are your guys input?
Old Jan 20, 2021
welll, at least you do know that the timing belt is good and how new it is.
Yes, I agree it's metal on metal noise. Do not sound like engine noises though.
He might be right
Old Jan 22, 2021
I eat crayons
Two quick bolts later I got the starter off. I took a video of how it looks because idk how it should look. I looked inside the the slot/hole that the starter goes into and saw well look at the video. What of it?
https://photos.app.goo.gl/1YyYTn5oCpmKHyQa8
Old Jan 22, 2021
they seem to be in one piece, the shiny spots are likely from the starter engaging?
Call your neighbor again to look
Old Jan 22, 2021
I eat crayons
He's not going to be available for a while. If it's not that what else could it be?
Old Jan 22, 2021
there might be some pieces of something rattling around the flywheel.
bad news is you will need to remove the transmission just to find out if that is the case or not.
Old Jan 22, 2021
I eat crayons
Could I not spin the crank shaft to see if it'll make noise?
Old Jan 23, 2021
I eat crayons
Im not sure if it's clear the audio on this video. But it seems to be stuff in some areas and then smooths out in some. Not sure if that's normal. I'm getting a few more tools and then I'm going to try to pull the trans.
https://photos.app.goo.gl/YB1Dff9KnidTb32C7
