View Full Version : Engine
- motor mounts..1
- Do I lubricate a new accelerator cable before installing it
- small oil leak coming from around the camshaft seal
- D17A1 cam plug - 2004 Civic
- D17A1 Fuel rail pulse dampener [solved]
- Thermostat leaking
- Lower Timing Cover Shredded + Oil Leak Issue
- Full reservoir empty rad over heats 3-4 weeks after coolant top uo
- Air leak sound, few seconds after engine is turned off [solved]
- Help pls
- Specs on oil pressure tesyt
- Fuel line connections?? Please help
- Serpentine tensioner
- 2002 1.7 EX help i am lost! [solved]
- Possible To Replace Motor Mount Stud (Alternator Side)? [solved]
- Broken stud on oil pump
- Is this engine worth rebuilding?
- Throttle going up and down after TBI clean
- Jumped Timing Belt?
- Catalytic Converter
- D17A1 suddenly burning oil like crazy
- Ignition timing issue
- Help! Identify Engine Part
- Car intermittently won't start.
- P0172 with throttle Bogg
- Fuel Tank Pressure sensor
- Car coasts for a while after starting
- 03 EX oil drain plug
- 05 Hybrid P1457, P2000, P1679 all at once
- 2003 Civic 1.7L Multiple cylinder missfire
- Issue with engine have spenta lot of momey still wont get fixed
- Engine oil for d17a
- 05 Oil pump seals replacement
- p0135
- Do I have a 1.7L engine?
- Civic 2001 P0203
- Engine leaking oil into exhaust manifold after new valve replacement.
- 2002 Honda Civic – ECU likely dead? Can I replace it?
- random misfire all cylinders
- Fueling issue
- Right spark plugs for 2004 Civic 1.7 sedan
- New (To me) Honda Mixed parts [solved]
- What is this? It looks
- 2004 Honda Civic Dx leaking coolant
- Tapping sound on my 2005 Honda Civic LX
- How to remove coolant overflow tank on ep3?
- Honda civic PO135 code 02 sensor
- 2004 Civic engine cutting out
- Civic 2004 no accelerating more tan 20mph after put a new intake
- Can’t figure idle surge
- 03 Si 5MT HB Purchase
- Coolant Overflow Tank Cap - Airtight or ?
- Nut identification
- 1.5/2 inch 10mm Mystery Bolt
- 2004 sedan EX fuel smell under the hood no visible leaks
- Need help with choosing right engine oil [solved]
- Head replacement
- Engne Rebuild advice needed!!!
- Multiple Missfires
- High Fuel Consumption
- Oil Seepage, source? [solved]
- Poured old motor oil into radiator--what now?
- Oil Light On
- D17A2 oil pan gasket - how much silicone?
- 05 civic engine replacement
- Rounded bolt- exhaust manifold heatshield
- Rusted through cat, replacement suggestions [solved]
- Head gasket replaced. Still blows white smoke
- Engine sputters when wheel is turned all the way
- need head gasket replac. advice
- Change your Harmonic Balancers(Crank Pulleys)!
- Car keeps jumping time
- D17A2 cam bearing issue
- 2003 Honda Civic Ex Misfire/ Running Rough + Stalling/ Low Idle
- coolant leak on passenger side
- Stalling civic help
- Is an exhaust heat shield replacement advisable?
- 2005 Civic Hybrid oil leak, from where?
- Ecm?( solved)
- D17A Cylinder 4 Misses only at idle [solved]
- Green key, no start, no power to OBD
- 2002 Civic Si 2.0 oil quantity mystery
- 2004 Civic - Gasoline Smell
- cooling fan issues
- Scan tool reads error
- 2003 Civic EX sedan- 5MT- misfiring and oil loss
- Head gasket
- 03 Civic LX Randomly boggs/dies
- 01 civic dx Vibrating rattle at 2000 rpms in gear or neutral
- Drive Belt(s) diagram
- check engine light on and of and on and off
- P0339 and will not rev over 3k
- where is the starter in a hatch K-series?
- Engine rebuild
- Average time for timing belt replacement?
- Civic ep3 temp gauge going up and down
- 2005 4 cylinder where is the heater control valve?
- P0303
- Car keeps coding
- Civic Ferio ES Vtec and EGR
- Only starts with crank sensor UNPLUGGED, 2005 civic ex
- Is radiator fans assembly supposed to move when jiggled
- 04 Civic DX, Manual Trans Idle Issues
- Low idle RPM Civic 2001
- Engine Failure ?
- Is it my new Rings or my new head gasket? [solved]
- Has anyone used these Catalytic Converters?
- 2 mystery spacers while putting engine back together after new head gasket
- Is there an idler pulley
- Could my pistons be bad or just head gasket?
- Grinding noise when starting and then goes away
- P1259
- Starts and runs fine until engine is warm
- Vacuum test where to connect [solved]
- Not grounding
- Tapping/Knocking when Under Load at Low Rpm.
- Random Intermitent Bucking/Jerking at High Speed.
- Could this cause issues with compression?
- 05 Si (US EX) Coupe starts first time, dies after 10min, won't start but cranks
- Blown
- Fuel pump shutting off repeatedly
- 05 1.7L Civic EX not starting
- Engine rebuild
- High RPMs?
- Car hesitates while cruising
- I need help n a diagnosis??!!
- D17a2 head fails valve leak test [solved]
- 2002 civic a/c always engaged
- engine will not shut off
- Reusable Air Filter
- Engine issue and I cant figure it out
- money shifted 3rd to 2nd 7th gen civic help!
- 2004 Honda civic loud start up rattling and vibrating
- Need help!! Fans not working unless jumped or A/C on (only for 1 minute)
- Honda civic 2004 O2 sensor
- 04 Civic Ex coolant reservoir lowering
- CEL after timing belt change [solved]
- Civic 2003 oil pump replacement?
- P0301 cylinder 1 misfire - pls help
- 2002 EX coupe 5MT with unresponsive gas pedal soon after starting... any ideas?
- Is this the right seal
- Best timing belt
- 2003 Civic EX 1.7l Head rebuild question
- Smog tests and pending trouble codes (California)
- Maintenance records Carfax - timing belt?
- Fuel injectors safety clips....optional?
- Just getting info from people to see if I'm panicking - timing belt [solved]
- 2003 Civic LX 1.7 Once Warm Stalls when in Drive, P0132, idles fine in neutral.
- Questions about oil leak at oil pump
- Click When Turning Crankshaft
- Unidentified part
- 2003 Honda civic with check engine light code p1130 and p0147
- 2003 honda civic with check engine light codes P1130 and p0147
- Ignition issues now a problem.
- Ep3 03
- 2005 Civic Hybid throwing P2000 code
- Cylinder inspection, new rings?
- Engine Idle Rough
- drive belt vibration when cold, and P0325 Knock Sensor code
- Smoke From Radiator
- Grinding Noise After Hot or Cold Start Up
- Motor Mount Hole Stripped?
- Constant voltage at 1.28 Volt Secondary O2
- New head or replace motor
- 01 Civic EX Rough Idle, Governing 3k RPMs.
- High idle and 4 check engine lights after engine swap swap Help please!
- Ticking noise from engine [solved]
- P0138 wire continuity
- 2003 Honda Civic EX 1.7
- while at it - change head gasket?
- P0138
- Can I use this because I don't use it much around the house?
- D17a2 Rebuild Question/help
- HELP!! Broken Valve Adjustment Screw!
- Help! 2001 civic loses engine power when starting to drive it
- 04 Civic Si (EP3) - P0172 & P0453 - Low MPG
- Idle issue
- SOLVED Unknown Nipple Cover??
- '05 civic lx no spark [solved]
- 01 Civic EX idle bounces even after I changed throttle body
- Choppy startup, followed by rough running and AT gear locking
- Limp mode? Bypass? [solved]
- D17A oil pan gasket
- Question on vapor bulb on end of fuel rail [solved]
- Drive belt tension
- 2004 EX, Keyless entry doesn't work. Car won't turn over.
- my timing belt
- Where should I put 02 sensors!?!
- 04 Civic LX Won't start after getting warm/only one chance to start at times.
- Civic not starting after replacing timing belt became loose
- Piston slap - should I be worried?
- EX auto to LX manual what could be wrong?
- wont start when wet, missfire, poor idle
- Misfire that runs well after clearing check engine light
- Part/component of Evaporative Emission System is missing [solved]
- Aftermarket pistons...vs old pistons
- Valve spring compressor D17A2 VTec
- EGR Issues
- Oil leaking out of front timing cover [solved]
- ‘05 Civic EX - Please say it ain’t rod knock!!!
- Turned off while driving on freeway.
- gasket for vtec assembly off of head?
- Help any ideas
- Car accelerates fine with light throttle and stutters when at full throttle
- Replacing my 2003 1.7 gas tank questions
- Major oil leak at oil pump area [solved]
- How Screwed Are My Cylinder Walls
- Head Rebuild
- 2001 Honda Civic EX fuel leak
- Please help
- Where can I get one of these
- P0141 after stolen cat [solved]
- Oil leak - 2003 D17a2 [solved]
- P2646 code... I'm stumped HELP
- replacement engine, vtec - all of them seem expensive?
- Cost of tightening both fan belts
- Timing Belt Tensioner Bolt upgrade...
- 2001 hona civic non vtech help please
- VTEC wiring help [solved]
- car won’t rev past 3500rpms
- 2001 Honda Civic EX - I'm Stumped
- Engine limiting RPM
- P0172 after injectors replaced
- More timing Belt problems on my 05 LX [solved]
- D17a2 head swap on a d17a
- want more mpg, new to this.
- Engine reassembly - help camshaft, timing
- Ep3 EML on (and off)
- Trying to get things sorted.
- Change semi synthetic x mineral oil
- What Spark Plugs for 2005 Honda Civic LX ? [solved]
- Rear main seal replacement
- Code after code issues
- I want the name of this hose
- Fixed 1 problem now I have another?
- 2005 Honda Civic Fuel Tank Pressure Sensor Location, Help?
- Dual drivetrain swap
- Timing belt kit
- running issues stumped and no-one seems to know [solved]
- CEL flashes 15 times battery light goes out then limp mode
- Timing marks on cam sprocket keep coming up off by half a tooth. [no start solved]
- 2005 civic struggling to idle when cold
- 2004 Honda Civic DX-G(Canada) Oil leak
- Belts squeal and hanging low on frame
- Fuel Cap Will Not Tighten
- Time-Sert question issue
- **FIXED**Weird Engine Noise when starting up, comes back when slowing down in traffic
- Ticking Noise
- Preventative Head Gasket when doing Timing belt? [solved]
- Leftover bolts from head gasket replacement? [solved]
