Vacuum test where to connect [solved]
Old Jun 7, 2024
Eros14's Avatar
Eros14 is an unknown quantity at this point
Hello, I’ll be doing a vacuum test for my car, it’s good and runs pretty well for the 150k miles, but my question is where is the best line for testing the vacuum system? I’ve heard brake booster hose…
Old Jun 8, 2024
re: Vacuum test where to connect [solved]
Brake booster line for sure. I used it as a vacuum manifold when I was turbo'd with my EM2. It does have a check valve in there, so there's some food for thought depending on if you're either cutting it to install a permanent T fitting or just want to disconnect something to test for vacuum loss as a one time thing. If you're installing a T, make sure it's upstream/engine side of the check valve. The only real good way to find it is by squeezing the hose
edit: pics from 17 years ago when I tapped the wrong side of the check valve for my vacuum manifold are in this thread: https://www.civicforums.com/forums/7...lem-fixed.html
the check valve is about an inch to the left of the T fitting I installed. Anywhere on the engine side of the white clip would be a good place to tap
Old Jun 8, 2024
Eros14's Avatar
Thanks for helping me out... Yes, the check valve in inside the hose. I will do a test not cutting nor installing something, but I think the valve will not affect the readings, since is a one-way valve.
lindylex
Sep 4, 2019 02:12 PM
nicholastiew
Dec 22, 2015 06:35 PM
SalPal
Jun 3, 2015 03:44 PM
SlimRisk
Nov 1, 2011 10:55 PM
bugzila
Jun 5, 2006 02:38 AM
