Tapping sound on my 2005 Honda Civic LX
Hey there, I just recently bought a 2005 Honda Civic LX and I was wondering if anybody may know what the tapping sound coming from my motor is when I wrap it up the tapping noise gets a little bit louder, I tried holding my finger against the purge valve and I do not feel the same sound when I hold my finger against it. I don’t know if there’s multiple other purge vowels or maybe there is only one. If anyone could help me out, that would be greatly appreciated
Re: Tapping sound on my 2005 Honda Civic LX
If you can, post a video. Depending on how loud it is, it could be normal or it could be as bad as rod knock.
here are a couple of videos from my 2002 civic.
In this video: , skip to the 11s mark and you can hear what normal tapping sounds like
In this video, you can hear what rod knock sounds like: . Fix for that one was a bottom end engine swap (I had a spare engine laying around)
In this video:
In this video: https://www.youtube.com/watch?v=k52y1BBItfE, skip to the 11s mark and you can hear what normal tapping sounds like
In this video, you can hear what rod knock sounds like: https://www.youtube.com/watch?v=ZUuRwnIf8GE. Fix for that one was a bottom end engine swap (I had a spare engine laying around)
here you go! Please let me know
Sounds normal to me. Could probably use a valve lash adjustment. Pretty easy to do if you're mechanically savvy and have a set of feeler gauges and probably takes 30-60min.
- Start with the engine cold
- Pull valve cover and upper timing belt cover. I'd recommend pulling spark plugs, too, so you're not fighting compression strokes for the rest of this procedure
- Set engine to TDC
- Measure clearance between valve stem and rocker (exhaust .009-.011"/.23-.27mm; intake .007-.009"/.18-.22mm) on cylinder 1 (closest to timing belt). Adjust as needed (loosen nut, turn the adjusting screw with a flathead, torque the nut to 14ft-lb)
- Rotate crank 180* degrees (counterclockwise)
- Repeat on cylinder 3 (making sure cylinder 3 piston is at the highest point of travel -- this can easily be done by sticking a dowel down the spark plug tube and watching it rise/fall. It should be 180 rotation of the crank pulley, however. I personally have the long bar from a broken plastic hanger in my tool box for that reason)
- Rotate crank 180
- Repeat on 4
- Rotate crank 180
- Repeat on 2
- Put everything back together.
acrobatic
Nov 24, 2010 11:45 AM
