Ticking noise from engine [solved]
Old Oct 30, 2023
Luciferr94's Avatar
Luciferr94 is an unknown quantity at this point
I have a 2005 Honda Civic EX SE and this is the first Civic I've ever had, is this a normal ticking noise? sound is most prominent at idle
File Type: mp3
Old Oct 30, 2023
re: Ticking noise from engine [solved]
Sounds like valve tick. It's fairly normal. If you're feeling frisky, do a valve clearance adjustment
https://www.civicforums.com/forums/1...djustment.html
Old Oct 31, 2023
Luciferr94's Avatar
Re: Ticking noise from engine
Ah okay thank you. If it is valve tick, is it the kind of normal where it won't cause any problems if it isn't addressed, or does it need to be taken care of?
Old Oct 31, 2023
Re: Ticking noise from engine [solved]
easy enough to take care of.
yes, many issues from consumption to wear to loss of power, etc
Old Oct 31, 2023
not terribly pressing, but it'd behoove you to get the valve lash adjustment done due to the reasons @sdaidoji said. Fuel efficiency, power, run smoother and quieter. Those are the big things that'll be affected
CivicN3wb
Feb 15, 2017 08:22 AM
siguy2
Mar 7, 2015 11:27 PM
blinduvula
Aug 28, 2010 11:34 PM
krazymatt
Jan 10, 2010 10:53 PM
