99 civic engine ticking noise
Old Mar 22, 2009
blinduvula's Avatar
blinduvula is an unknown quantity at this point
Good morning all!
This is my first post so first of all I would like to say thanks in advance for any help and I am glad to be a member of the community.
but now on to my issues... So I just picked up a 99 civic HB last Thursday and when I test drove it everything was flawless and quite... well over the last few days I have noticed a ticking noise coming from the engine when I accelerate. After about a mile or so the noise goes away completely. I stopped by my local NAPA in search of a universal antenna and the guy that checked me out happened to be a Honda enthusiast. He came out and listened to it and claimed that the valves just need to be adjusted and that its nothing really to worry about. Now… I don’t know too much about cars (yet) but I was hoping that maybe someone could help me out with this issue and give me a little more insight? Also if it does just need a valve job could anyone recommend me a shop in the Des Moines area that would be trustworthy and maybe the average going rate of a valve job?
Thanks again!
Old Mar 29, 2009
mvracing's Avatar
mvracing is an unknown quantity at this point
Re: 99 civic engine ticking noise
Sounds like the valve or bent rod! Get it checked out asap or new motor soon!! I had the same problem and it cost me a new motor!! I was racing one day(at the track) and missed shifted and the noise started from there, it really sucked!! But w.e. get it check out ASAP!!!
Old Aug 28, 2010
Toffee's Avatar
Toffee is an unknown quantity at this point
Yeah i have the same issue, but it ticks 24/7 i dunno if its my timing belt or the 99 VTEC DOHC engines do that
Old Aug 28, 2010
Mad Dog Tannen's Avatar
It is probably just a loose valve. You do no need a valve job, you just need to adjust them. It says to do it every 15000 miles on my car, it is probably about the same with yours. Get a haynes/chilton manual and it will show you how to do it. Get with someone who knows how to use a feeler guage to show you how much "grab" you need to have. The only special tools you might need are a feeler guage (the bent kind and maybee a offset wrench or they make special wrenches for doing it also. It is at most an hour job if you have never done it before.
Toffee: You have the same engine as me, you are supposed to adjust your valves every 15000 miles!
mvracing: Hondas are notorious for having valve tap noise, because most people don't adjust them when they are supposed to. Don't assume it is a bent rod just because of valve tap.
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
Grey
Nov 9, 2001 09:41 PM
godka0s
Bolt-on Engine Performance
Nov 8, 2001 07:16 PM
