2005 civic struggling to idle when cold
Old Apr 3, 2023
Civiczele's Avatar
Civiczele is an unknown quantity at this point
I recently changed my downstream, O2 sensor and upstream O2 sensor with these parts.
2349005
2344092
car immediately had trouble on cold start I’m very confused on what o2 sensors are correct.
car has new iac. And a new car
Old Apr 4, 2023
Colin42's Avatar
Re: 2005 civic struggling to idle when cold
Aftermarket iac? Did you use denso o2 sensors? Did the upstream sensor cost significantly more?
Old Apr 10, 2023
Civiczele's Avatar
these are Denso sensors. World pack says to use a different one.
aftermarket iac.
Old Apr 10, 2023
Colin42's Avatar
Aftermarket iac can definitely cause issues
Explain this better
Old Apr 10, 2023
Civiczele's Avatar
Explain this better
this all started after I installed new o2 sensors. I’ll get the new part number tomorrow. And how can I see if the iac is actually causing the problem. Onky code I have is evap
Old Apr 10, 2023
Colin42's Avatar
There's a port you can cover in the throttle body to test. Search iac testing on the forum or on google.
Hotion
Mar 28, 2021 06:49 PM
2005ex
Idle Issues
37
Aug 2, 2019 11:43 PM
TripleThreat719
Jul 27, 2014 07:35 PM
Hondacars
Idle Issues
Jan 2, 2014 05:18 PM
fleming100
Aug 3, 2011 12:20 AM
