View Full Version : Engine
- 04 Lx Acceleration Issue
- Intermittent engine stumble/dies
- 04 civic lx afr and oxygen sensors
- Timing belt
- High Rpm Low engine speed/hesitation
- 2004 LX o2 sensor malfunction [solved]
- 04 Civic EX Check engine light came on while driving
- 2005 civic ex clicking noise
- High Fuel Trims And Crappy Gas Mileage (No Check Engine Light)
- Low power
- Another knocking question... [solved rod bearing]
- CKP sensor problem on a Civic 2003 EX Error p0336
- Thermostat stays on cold (2005 DX) [solved]
- P1361 Code
- Oil pump seal steps
- won’t go past 4k in 4th gear
- D17b2 oil pan swap
- ECU relearn
- Cranium
- 2004 Honda civic 1.7 L crankshaft sensor
- honda civic 2001 resonator box removal
- Random pinched off tube? Please help! ('02 civic LX manual)
- Is this an acceptable surface finish on my head
- Weird Bogging When Cold (Video) [solved]
- No spark
- Odd spark plug tube seals [solved]
- O2 Sensor Question
- Transmission light and issues after engine replacement [solved]
- blew my motor. need a little help
- 2001 Civic emissions problems.
- 2003 civic ex jerking
- 2004 Honda Civic EX Coupe (258,000+ miles) - poor fuel efficiency, slow acceleration
- Squeak became a knocking
- 05 Civic Shut off while driving and will not start back up
- Excessive oil consumption - 2002 Civic
- 2003 civic ex, starts runs for 30 sec. Then dies. [solved]
- 2005 2.0L K20a3 timing chain jump
- Check engine / idle issues
- Vacuum Lines
- Multiple header problems D17A2
- '01 Civic LX has intermittent shake(kick) at idle [solved]
- P0340 P0341 - 2003 Civic LX 140k
- 3500 rpm engine sputters but does not die
- Oil Leak [solved]
- What spark plugs from Autozone is recommended? 2004 EX
- Head Gasket Repair or Engine Replacement?
- Leak down test: must engine be cold?
- What is the circumference or radius of the crankshaft pulley?
- What is the firing order for 2002 Civic LX and how to crank engine to get to TDC?
- Terrible Grinding Noise
- Arai, Nok? Also alternate OEM part numbers?
- D17A2 oil pump seal gap
- Fuel Injector O-Ring
- Unstable fuel economy.
- My Engine SINGS at 2500 rpm...
- Denso ignition coils any good?
- Check Engine light after stalling
- P1457
- Replacing the exhaust donut bellow the manifold (hatch 2.0L)
- Money Shift
- Camshaft position sensor
- Proper throttle cable position?
- Cylinder Head woes
- Car runs for a little while, sounds like sputtering and almost stall out while drivin
- Cylinder head noise
- Heater core flush
- Does this valve look okay?
- 05 Honda Civic LX Timing Belt Tensioner Bolt problem [solved]
- Belt squeaking, which is the more likely culprit
- Help finding & replace parts
- rough Idle Stall and temp fluctuates [solved?]
- Engine noise help
- It runs but it’s a hot head [solved]
- A confusing one
- Check Engine Light P1259
- 2002 Civic LX fuel rail feeder hose location
- 7th Gen timing belt tensioner bolt hole...
- Occasionally feels like it stalls
- Damn pan
- 2001 EX oil leak
- Major misfire or fuel problem
- Ring a ding dang a ramalama [case closed by OP]
- Jacking the engine
- White smoke after replacing alternator
- P1491 Exhaust Gas Recirculation Valve Insufficient Lift
- primary 02 sensor ground help
- 01 LX, Sudden CEL, Limp mode, P1361
- Replace camshaft seal without removing tension from timing belt?
- Help with valve cover gasket replacement
- Help with timing, installing cylinder head on the block
- Slight ticking sound - at idle and under throttle...
- Help with oil leak
- Growling Sound at Low RPMs [solved]
- Civic is losing power and acceleration [solved]
- I have 3 codes that are all related
- Valve lapping [solved]
- P0122 / TPS Sensor reading below expected voltage
- Resonator renovation
- Honda civic 2004 shut down ,when AC is turn on
- Rev limiter at 4k rpm
- P0420 from a Cold air intake
- Might as well change it all [closed by OP with no change in rings]
- Need help!!! Don't know why engine will only spin 1/2 way then lock in either directi
- Need a Little Help.
- 2001 Honda Civic lx stock pinging???
- Honda Civic ferio 2005 ES1 - Engine D15B CVT swap problem
- P0131 error after working engine hard
- 2003 Civic Ex Oil Leak
- Engine Smoke after vehicle was idle for a few years
- Need help!!! Engine has 4k rpm limit
- Check engine light
- Gen 7 stripped valve cover hole [solved]
- Oil seals
- 2003 civic dx horrible mileage
- Head Gasket Replacement? [solved]
- Replacement cam sensor
- 2001 civic EX exhaust leak [solved]
- Please help. Finally found something out of place.
- Civic 2003 si 157k
- Headers glowing red after idling for 10+ min
- Does the D17A2 have a timing belt thrust plate?
- car stalls coming to a stop
- vtec works fine when cold but bucks at 3500rpm when up to OT.
- Aluminum oil pan 1.7 L
- issues after swap
- Crank But No Start - High Miles
- 02 Civic EX lack of power on hills no cel
- Acura EL 1.7 struggles going uphill
- Help me find correct motor please
- Jerking when in 5th gear and light throttle
- Check Engine Light On - P1362
- 1.7L VTech really GUTLESS!!
- Oil leak around cam pully [solved]
- Rear mount
- Re: Low Oil and Vtec Solenoid Issues p2646
- Exhaust Manifold Rusted, leaking
- 2002 civic ex belt issues
- Rough idle or surge - [information] beware of different gaskets - EGR hole
- Question about ECU 37820-PLM-C72
- 2005 Civic LX feels like rev limiter kicks in at 3500 rpm?
- Vtec-E
- 2001 New Honda Crate Engine? Anybody know where I can buy?
- Worn woodruff key for harmonic balancer
- Exhaust Manifold/Cat Replacement
- Idles after ECU reset until next car start
- Slight loss of power from a dead stop
- Factory Service Manual
- Head Gasket Time - 2002 EX Coupe
- Engne stalling
- SE EX Airbox Rattles
- Squealing noise when starting car
- What VTEC solenoid for 2002 EX w/D17A JDM engine, USDM ECU and wire loom?
- Does the JDM D17A have a different air filter?
- Loss of performance + High usage of gas
- Source(s) of Oil Leak?
- 2005 LX Cheap Exhaust Manifold/Cat Replacement
- Rear main seal leak? [solved - not seal]
- Complete rebuild
- 01 Civic LX Sedan Exhaust Replaced Now have vibration.
- squea
- 2001 civic oil leak unknown origin [solved - VTEC solenoid leaking - uncommon]]
- ???I've got a couple engine questions???
- Intermediate loss of power on acceleration and rough idle
- 01 civic LX sedan Exhaust 02 sensor questions
- Need to fix block head bolt threads
- 7th Gen Head Gasket
- Walmart oil change failure
- oxygen sensors [solved]
- radiator coolant fan switch
- Manual tranny with Auto motor. help
- Rear main seal too deep?
- Any harm in doing a valve clearance adjustment?
- Oxygen sensor
- 2001 civic LX rattle wobble noise on startup
- Timing belt
- 2001 civic vtec wiring does not come apart and I don't want to break anything
- Poor performance/Limp mode? --- Solved!
- Stripped oil pan studs
- Proper belt tension
- Engine running smooth
- 2005 Honda Civic EX Coupe Squeal
- Need Advice on How to Handle AC Clutch Issue and Broken Belt
- Car heats up it loses power acceleration feels like it's stuck
- Fuel Octane causing PO302 ????
- 2005 Honda Civic AF parts number
- Oil Pan Leak
- Cylinder Head Assembly Replamcement
- 01 Civic Engine and Transmission Mounts Part Number [solved]
- Header & Cat Delete P420-P1420
- Having a weird idle issue, just swapped heads.
- Heater core hoses
- Manifold bolt
- Compression on a 2003 with 240k miles
- Oil leak
- 02 Civic EX All Cylinders Misfiring
- Timing Belt Broke - Cost to swap in a head etc?
- Cam shaft end plug
- Heater hose
- Identify this plug(05 ex civic sedan)
- 04 Civic intermittent bogging
- 2001 LX - Gas in the oil?! HELP
- 2005 D17A2 Code P301 [solved]
- Snapped bolt during thermostat replacement
- Oil pressure sensor
- Timing belt noise
- Throttle body
- D17A valve issue, misfire when cold and shaky idle *long read please help*
- 7th gen , P0722 honda part numbers
- P1362 code keeps coming up after TDC sensor replacement.
- Low engine power and 02 sensor problem
- Engine Bog Down And Then Dies
- P0139 code [solved]
- What's your idle RPM while coasting?
- Engine shut down while driving and would not start again
- Radiator plug head broke
- Removing block heater to drain engine block coolant
- 2003 Civic LX 126K miles. Shaking ONLY during cold startup ( Cold weather only )
- Black sludge in coolant reservoir tank
- 02 civic loses power after warming up.
- Low Power W/ A. C. On
- Ckp bypass 04 Honda Civic
- Knocking / ticking noise around timing cover
- issues after replacing CPS [solved, bent pins]
- 2004 Civic VP TPS
- 2004..Exhaust centre /resonator... Price ??
- Crank shaft pulley removal 03 civic ex
- Long term effects of using non fouler?
- manifold/cat replacement
- 2003 EX P0401 continued issues after repair
- Downstream O2 sensor P0141
- ISO 02 Honda Civic Ex D17 A1 motor
- Throttle/idle issues. Jerk when throttle de/pressed. Vaccume leak?
- '02 Civic misfire at idle cylinder 4
- Honda start driving slow then shuts down
- Engine Surges When Pressing Brakes
- need help . 02 civic lx non vtec powerloss\backfiring, undrivable after warm up
- Headers Glowing Red
- unusual rough start up noise
- P1361/P1362, 2002 Honda Civic, and oil leak treatment
- HEAD BOLT — Not like the rest!
- Maintenance Required light.... [solved]
- Civic 02LX SOHC Automatic Oil leak
- 2005 Honda Civic EX Stalling Randomly
- Crankshaft won’t turn
- Empty oil filter
- Misfiring ahhhh [solved]
- New car problems
- Swap
- Car making knocking sound
