Car runs for a little while, sounds like sputtering and almost stall out while drivin
Old Aug 13, 2022
24lutzs's Avatar
24lutzs is an unknown quantity at this point
So this has happened a few times now. I have a 2002 Honda Civic ex coupe 5 speed manual. After warming up and getting ready to go civic is fine. After driving for a little while the car will make a missfire or sputter noise and will slowly stall out and miss acceleration. Idk if this has anything to do with it but I also noticed the car has been running very hot, almost to the H even at idle sometimes. Someone please give me answers because I have no clue where to start besides fuel injectors.
Old Aug 13, 2022
Colin42's Avatar
Re: Car runs for a little while, sounds like sputtering and almost stall out while dr
If its running hot i would start with the cooling system. Not with fuel injectors. Check engine light on? Does it work?
Old Aug 14, 2022
24lutzs's Avatar
Yes it works it runs beautifully until it makes a sputter/missfire noise and misses acceleration and stalls out. the only code is the 2nd o2 sensor but that’s bc it’s straight piped
Old Aug 14, 2022
Wankenstein's Avatar
From a cold engine (ex: parked overnight) start how long does it take for the temp gauge to read above over the halfway (between cold and hot) mark?
Reasons for hot engine:
Closed thermostat
Low coolant/coolant leakClogged radiator
Blown head gasket causing internal leak in cylinder(s)
Falling or failed water pump
toddns
Transmission
Dec 3, 2021 02:40 PM
prr
May 5, 2017 10:15 PM
ashokudu
Jan 7, 2010 02:47 PM
weswing04
May 21, 2009 12:52 PM
rudybellavia
Jan 15, 2007 10:31 PM
