Did I screw up my transmission?
Old Dec 3, 2021
toddns's Avatar
toddns is an unknown quantity at this point
Earlier I was rolling slowly backwards in my 2011 automatic(no gas being used, just engine idle) & without thinking I put the car into drive before fully coming to a stop. I didn’t hear any noise & the car pulled into the driveway no problem.
few hours later I start it and it’s idling a little rough. I back out of the driveway, still idling rough, come to a stop and put the car in drive. I push the accelerometer all the way to the floor and the engine doesn’t rev at all. It’s still idling low and a little rough. Put the car in Park & it will rev up. Nothing in Drive or any other gear.
if I damaged the transmission would that cause the engine to idle rough and stop revving altogether while in Drive?
any advice would be great before I have it towed to a shop.
thanks
Old Dec 3, 2021
toddns's Avatar
Re: Did I screw up my transmission?
Update: I got the car turned around(it moves slowly while idling-always has).
while facing downhill I let it roll and gave it gas & it went.
Pretty sure I forked up 1st gear. When it 2nd and driving it shifts a little hard into 3rd. Haven’t gone beyond that. I’m in a residential area so get can’t speed up.
Old Dec 3, 2021
CEL on?
slowly moving backwards and engaging drive does not cause any issues with my auto CX-5
Old Dec 3, 2021
toddns's Avatar
Originally Posted by sdaidoji
CEL on?
it wasn’t initially but it is now.
I just had it towed to a transmission shop.
Old Dec 3, 2021
BrotatoChip's Avatar
Super Moderator
I suspect the engine is in limp mode, instead of a transmission issue. CEL would shed light on what's wrong.
Modern Welfare
Nov 28, 2019 02:49 PM
gulzarh
General 7th Gen
May 11, 2017 07:16 AM
esch
Dec 25, 2009 01:40 PM
CuRiOuSfIsH
May 1, 2005 07:43 PM
FiresVTEC
Jan 21, 2002 02:34 PM
