8th Gen 2006 - 2011.
Two minor, but irritating problems
Old Dec 18, 2009
esch's Avatar
esch is an unknown quantity at this point
First time forum member.
I purchased a California, manual transmission ’06 EX Civic several months ago and have noticed several problems which are not serious, just irritating and not what I would expect from a Honda.
The first is a slightly rough idle which occurs at about 600 rpm – the normal (i,e,. warm engine) idle speed for this car. The second problem is what I believe is called “drive line ******”. This slight “jerk” happens when I apply pressure to the accelerator after letting up on it to deaccelerate (all the time in gear). These two problems seem are not as apparent when the engine is cold and the idle speed is about 700 rpm. I live in Ohio and wonder if the California specs on this car may be causing the problems?
When I purchased the Civic, I figured that the above problems were minor and I would adjust - wrong. I find them irritating and hopeful that they are correctable. Thanks in advance for any advice.
Old Dec 25, 2009
plastics's Avatar
plastics is an unknown quantity at this point
Re: Two minor, but irritating problems
California cars are tighter spec for emission and is more sensitive to the gas and quality you use.
Gasoline with alcohol , some engines are very sensitive to that, and doesn't idle well because the alcohol burns much later and the computer thinks something is wrong and trys to compensate and turns in to the rough idle and bad idle quality you mention
you may want to try a quality gas without ethanol if you can find it and it should make better idle quallty..but may be hard 2 find the gasooline without the alcholl at ohio cause it is close to corn.
Old Dec 25, 2009
rocksinger45's Avatar
rocksinger45 is an unknown quantity at this point
Member Plastic is right, don't use cheap gas such as ARCO a lot of alcohol in that brand, I use 76 gas much better performance for a couple of penny's more... I live in L.A.
nefliminator
May 28, 2015 10:18 AM
Jigee
May 9, 2015 11:18 AM
cloudguy
Apr 28, 2015 05:02 AM
