2012 civic lx manual trans no buttery smooth shift unless I slip the clutch
Old Aug 1, 2021
quartermilecame's Avatar
quartermilecame is an unknown quantity at this point
80,000 miles on this car and I notice that at lower rpms, the lower gears dont shift smooth unless I slip the clutch/not press pedal to floor.Seems there is a narrow sweet spot of hand pressure plus dont shift too low rpm and clutch pedal release max height to push pedal. Pushing pedal to floor gets a more jumbly shitty shift. Have read about the shift it at higher rpms and also read on 9th gen civic forum that slipping clutch does help. Shifting is not super horrible in general but its not as smooth as my 2001 civic. Going to change the manual trans fluid out which I would think would still be factory fluid for the same oem honda parts shelf fluid just to see fluid condition and know fresh fluid is in there. Must be an issue as there are many posts on the subject.
Old Aug 1, 2021
Re: 2012 civic lx manual trans no buttery smooth shift unless I slip the clutch
check also clutch slave cylinder, shifter linkages, shifter assembly.
Old Aug 1, 2021
I dont see the clutch cylinder leaking. shifter linkages appear ok unless maybe bushings worn but at 80k miles?
Old Dec 25, 2021
Not pushing the clutch in but only about half way down gets much better shifts. This is just plain weird
Old Dec 25, 2021
are civics really supposed to be shifted at higher than 2k rpms? My 01 civic does this as well.
Old Dec 25, 2021
there is no need to do this
Old Dec 25, 2021
no. I can shift without pushing the throttle if speed and revs are correct
they must be correct, engine and speed and gear
Pnutt559
General 8th & 9th Gen
Jul 11, 2021 03:18 PM
ykf7b0
Transmission
Feb 10, 2018 03:50 PM
bacascooby
Dec 20, 2013 07:48 PM
chadkassinger
Sep 12, 2013 08:54 PM
Lalo23
Dec 25, 2011 09:11 AM
