transmission problems
Old May 26, 2013
chadkassinger's Avatar
chadkassinger is an unknown quantity at this point
My transmision shifts fine sometimes its hard to shift into 1st gear and grinds when going into second. Could this be a result on low transmision fluid?
Old May 26, 2013
Re: transmission problems
Get under there and LOOK for yourself.
It's faster than waiting for a guess from someone that can't see the car.
Random ideas:
Clutch fluid low (or adjustment if cable type)
Trans fluid low or old
clutch not releasing completely
Clutch disc bad or drag
clutch disc hanging on the input shaft splines, lack of lube
Pilot bearing bad or drag
Pressure plate bad
Trans wear/real trans problem
Bad habits/techniques
Floor mat piled up under the clutch pedal
Old May 30, 2013
Yea I should just tear into it but I don't have allot of time because of work. I do have some play in the clutch petal tho. And as far as the tranny problems sometimes when I am taking of from a stop in first gear your can hear the gear mesh through 1st and second gear and then its fine. And when shifting into first gear from a roll your can hear it kind of whining. I'm about to just change the fluid because i have been hearing that could be all of the problem. I am new to Honda civics and don't know which fluid to use I even went to my local auto zone and they had no clue. All the trans fluid they sold were for auto cars. And the gear lube/oil was a heavy duty
Old May 30, 2013
Honda dealers sell Hondas Manual Trans Fluid.
Guaranteed to be the correct fluid.
Old Jun 3, 2013
Alright man thanks
Old Sep 11, 2013
civic one's Avatar
civic one is an unknown quantity at this point
if you dont have any history about the trans itself, then most likley the trans is getting worn out ( shaft bearings and syncros ) . in gen. 6s deinstall and install isnt as bad as it sounds,, dont by a junk trans. take your time doing the job ...... I have a reond. d-16 with papers ready to go..?
Old Sep 12, 2013
Fliptard's Avatar
Fliptard will become famous soon enoughFliptard will become famous soon enough
all trans whine when moving and shifting into 1st. You should ONLY shift into 1st if you are at a complete spot or are going under 10mph
Old Sep 12, 2013
youmadeyou's Avatar
youmadeyou is an unknown quantity at this point
I'm having the same Problem . I'm going to try to Swap out the Clutch slave Cylinder & Master cylinder because I have read that this could be the problem.. I will let you know if it fixes Mine as soon as i install them. and Bleed them ..
Also You may just have Air in the lines . Try Bleeding your Clutch , it helped mine a little at first.. hope this helps .. To Be Continued ....
MajTom
Jun 2, 2015 11:48 AM
Schneiderman
May 24, 2015 01:14 PM
cruisers10
May 12, 2015 10:46 PM
Jessica Leung
May 5, 2015 05:12 PM
markp94
Apr 30, 2015 09:19 PM
