Thermostat stays on cold (2005 DX) [solved]
Old Jan 27, 2023
TNR1975's Avatar
TNR1975 is an unknown quantity at this point
Just today my thermostat stopped working. It stayed on cold during my one hour drive this morning. I also noticed when I'd come to a stop sign with it in neutral (it's a 5 speed) the engine was idling high for 3-5 seconds before returning to normal. Does it sound like I just have a bad thermostat? I need to drive it an hour to get home from work. Would it hurt if I drive it home?
Old Jan 27, 2023
Colin42's Avatar
re: Thermostat stays on cold (2005 DX) [solved]
Do you get heat out of the vents? Or does the engine never come up to temp? That way you know if it's a sensor issue or if the thermostat is bad.
Old Jan 27, 2023
BrotatoChip's Avatar
Super Moderator
I hope you've checked your coolant level recently.
Old Jan 27, 2023
If anything, better that the thermostat is stuck open than stuck shut. If it never fully heated up, it does sound like a stuck open thermomstat
It's pretty easy to remove and test, and testing only costs you a jug or 2 of coolant and maybe an hour or your time. Replacing it is a cheap and fix, too. You may want to buy a thermostat before testing it if it does show to fail (or replace it anyways because you'll be in there regardless)
Remove the thermostat (drain coolant, remove lower rad hose from thermostat housing, 2 bolts holding thermostat housing on)
Physical check: Check that is actually does move by holding it like a syringe and pressing your thumb on the flat end
Operational check: Toss the thermostat in a pot of water and put it on the stove, see if it opens up when the water heats up. Having a thermometer helps, but not 100% necessary. If you have a thermometer, it should start to open at 168-170F/70-80C and be fully open at 194F/90C, and it should open about 8mm
If it passes the op check, then return the one you bought (or replace it if you're so inclined), fill and bleed your coolant, and keep hunting
Old Jan 27, 2023
i think some had issues with aftermarket thermos, get OEM
Old Jan 27, 2023
TNR1975's Avatar
Yes, the heat works fine.
Old Jan 27, 2023
TNR1975's Avatar
The coolant has been checked recently and everything was fine.
Old Jan 27, 2023
TNR1975's Avatar
So, I drove it again and got home fine. A couple hours later I tried to start it and it turns over but will not start. Thinking it's the coolant temperature sensor. Any thoughts?
Old Jan 27, 2023
Colin42's Avatar
So the gauge doesn't work? Hopefully just needs a new temp sensor. Don't buy aftermarket, only buy an oem sensor
Old Jan 28, 2023
TNR1975's Avatar
(FIXED) Replaced coolant temperature sensor. There are 2 sensors, I just know the one I replaced was not the one where the coolant has to be drained.
MizKJG
Jan 6, 2019 02:55 PM
2002ExCivic
16
Nov 29, 2016 08:29 AM
Buttercup
Apr 20, 2013 07:34 PM
nick3501
Jan 9, 2011 07:55 PM
ehcees
Jul 26, 2007 02:10 PM
