Replace camshaft seal without removing tension from timing belt?
Re: Replace camshaft seal without removing tension from timing belt?
Not something I'd do. Back the tensioner off again, you can use a nail or small screwdriver if you dont have the original pin to lock it.
The original question here has to do with trying to get around pulling PS pump, alt, engine mount, crank pulley, etc to change camshaft seal. You know, just remove cam gear (mark belt + gear), replace cam seal, and then reattach cam gear with already tensioned t-belt? Are you recommending against trying that because thought I've seen youtube mechanics doing it that way. It would save a lot of time + work that's why I'm asking.
5.0Thunder
Sep 20, 2017 07:27 AM
civicNivik
Feb 28, 2015 11:06 PM
gotcivicback
24
Mar 24, 2014 08:29 AM
