Timing belt replacement?
I have a 2001 Honda Civic EX coupe that I bought recently, yet on the carfax it has no information about the timing belt being replaced, which leads me to assume it never was. The car has about 150,000 miles on it, and I am wondering what suggestions you guys have that I can apply to this?
Should I keep it safe and pay the $600 it will cost to replace it? Or take the risk and not replace the belt to save the money it will cost?
Any help is appreciated.
Re: Timing belt replacement?
deff do wut tbohar said. but personally with it being unknown if it was ever replaced even if it looks ok i would change it. there is a decent diy on the forum but if u dun feel 100% confident just pay the 600 an keep it safe. the 600 u pay to keep ur motor safe is better then the belt breakin an causing worse damage. thats just my .02 an im a feak for keepin up on that stuff.
replace it, its not hard at all to do. Dealers just scare you with "if you don't put it on right with the cam and crank aligned it will blow up", that's the only hurdle, just take your time and double check your timing marks when putting new one on. Very easy
definitely replace it! i bought an 02 ex for 500$ because the belt broke. im in the middle of replacing the head and belts and all that ****. im doing the work myself and its costing me about 600 or so just in parts. for the minor cost to just get it done its work it. you dont want to have to deal with it if the timing belt snaps. chances are you will have to replace the whole engine.
Basic Run Down.
Remove plastic shield, jack up car on driver side, remove driver side wheel, remove the the coil packs, remove alternator, move power steering pump to side, remove metal bracket that holds alternator and power steering pump on, place secondary jack and wooden 2x4 to support motor, remove driver side motor-mount, remove valve cover, remove upper timing, remove crank puilley (use crank pulley tool), remove lower timing cover, and walla you have accessed the timing belt.
**just make sure that timing belt crank pulley and camshaft pulley are lined up on their marks before putting new timing belt on**
Yea it's pretty easy. If I could do it anyone can really... The only special tools you need are the crank pulley remover tool and a belt tension checker, a big breaker bar and some pipe in case you need some more strength. I mean, cost rundown:
Timing belt : 30 bucks?
Pulley remover tool : 30 bucks?
belt tension checker : 15 bucks?
Water pump : 80 bucks
Tensioner : 80 bucks
Valve cover gasket + all other gaskets maybe 50 bucks.
roughly 300 dollars or so and your changing the water pump and tensioner too which isn't included in the dealer cost. This includes some tools too that you get to keep.
wow must be nice to live in the states
here in canada water pump = 130
tensioner = 130
belt = 30;
but if your there already you might as well change the tensioner... as well as some of the gaskets and such that you come across.
tensioner = 130
belt = 30;
its not a tensioner checker, its a tension checker. You can get it at most parts stores... the pulley remover tool call around. i think its a 55mm hex or something like that.. worst case scenario you have to get it online. this is something you should have in your hands before you start the job, otherwise you might be waiting for its delivery halfway through the job.
Just check it first, I pulled mine at 90k and it looked brand new. It probably could have gone another while. But at 100k your getting pretty close to replacement time.
when you get the timing marks set and the belt in place i held the i put a little tension on the belt with my fingers then pulled the belt tensioner pin and walla perfect tension (i did this as a preventative measure so when i pulled the pin it didn't knock one pulley out of timing)
i just got my car back from the mechanic. he changed my timing belt, water pump, and all seals. i decided to take it there because i was nervous about a diy attempt. 2 WEEKS AND $600 LATER i get my car back. it should only take 2 days and about $150 if you buy all new seals and everything, VC gasket included. After pouring over diy tutorials and videos for a couple days, i am sure i could do it myself.
don't psych yourself out. just do your research and take your time.
mattdoc
Mar 14, 2017 12:10 PM
