2003 civic ex, starts runs for 30 sec. Then dies. [solved]
Old Nov 26, 2022
Templarjj75's Avatar
Templarjj75 is an unknown quantity at this point
Having an issue with a 03 ex. It will start and run normally for 30 sec maybe a min. Initially, then die. I have checked timing, it is spot on, no check engine light. If try to start again, it will only run for a couple of seconds maybe and die again. Anyone ever had something similar happen?
Old Nov 26, 2022
Colin42's Avatar
re: 2003 civic ex, starts runs for 30 sec. Then dies. [solved]
Does the check engine light work?
Old Nov 27, 2022
Yes all the lights work.
Old Nov 27, 2022
Colin42's Avatar
Need to see if you're missing fuel or spark when it's trying to start. Any parts replaced recently?
Old Nov 27, 2022
It has fuel, I'm not sure if it's loosing spark or not when it dies
Old Nov 27, 2022
Colin42's Avatar
Need to check that
Old Dec 4, 2022
So I found I had a code for ELD, voltage too high. (No check engine light though). Got car to run long enough to check charging voltage, and was 16.47 at battery and 17v T alternator. So I figured it was a bad regulator in alternator and got a new one. Installed new alternator and it is doing the same damn thing...wtf?? What controls the alternator output voltage in this system????
Old Dec 4, 2022
Colin42's Avatar
Did you buy an aftermarket alternator?
need to be oem, junkyard if you don't want to buy new
Old Dec 4, 2022
Point being, the oem alternator was doing the same thing...
Old Dec 4, 2022
FRSam's Avatar
Click Here
That would suggest your OEM alternator isn't working properly. Replace it with another OEM alternator.
Old Dec 4, 2022
And so, why? I have used reman alternators before with no issues. What makes a 2003 honda civic ex so special? Are they not just refurbished OEM alternators?? I mean, you sound like a honda parts rep...
Old Dec 4, 2022
FRSam's Avatar
Click Here
Honda's are notoriously picky with aftermarket electronics. Given some quick reading you can do here, the most common electronic failure on this forum concerns aftermarket components.
I have no affiliation with Honda besides being a moderator on this forum. I'm a university student.
Old Dec 5, 2022
previous cases of aftermarket alternators not working for these cars, really, over the decades.
Old Dec 5, 2022
Colin42's Avatar
Pretty much every week someone posts here complaining of issues with the aftermarket alternator they just replaced
Old Dec 7, 2022
So I replaced the alternator again, and this one is working fine. However, still doing original issue..will start n run for about a min first time, then just start and die.
Old Dec 7, 2022
Colin42's Avatar
So back to checking if it's losing spark when it dies
Old Dec 7, 2022
Ok so how do i do this? I would think it's getting spark since it will start again...but die
Old Dec 8, 2022
Colin42's Avatar
Maybe it's losing crank or cam signal then, got a scanner that does live data?
Old Dec 15, 2022
So a code finally showed up.p0108..map sensor voltage too high. And it seems to start and run now while light is on..so weird..would map sensor cause this?
Old Dec 16, 2022
BrotatoChip's Avatar
Super Moderator
It very well could.
Old Dec 16, 2022
Colin42's Avatar
Unplug the map sensor and see if it runs
Old Dec 19, 2022
Ok so I replaced the map sensor and....it's running fine now...so weird...but glad it's working now...thanks to everyone for suggestions though!
slag
Jul 13, 2020 09:25 AM
jimd674
16
Feb 27, 2014 06:52 PM
pittbull121
Sep 28, 2012 12:48 PM
loboelprofugo
Apr 11, 2010 07:49 AM
