Odd spark plug tube seals [solved]
Old Dec 19, 2022
beersnob11123's Avatar
beersnob11123 is an unknown quantity at this point
'05 Civic Si, K20a3. Apparently, based on parts searches and youtube videos, I have some odd spark plug tube seals. They aren't just a doughnut-shaped ring. The holes in the valve cover have 2-3 of what I suppose you'd call flanges, so the main part of the seal probably looks like most of what I've seen from the under-side of the cover, but it has a thin rim that seats on a flange. Above that the seal wraps around that flange and has a ~8mm part that seats against the wall of the hole in the cover and ends at another thin flange inside the hole in the cover. The seals were brittle and leaking and were practically fused to the cover. Don't have a pic, but if you've seen it, you'll know what I'm talking about. Anybody know a part number or a how to video for installing these? Asking because online retailers' pics all just look black rings, which is 100% unhelpful.
I got replacements, which are total garbage (DNJ/Partsology) and unusable, since they get pushed off the cover rather than slide over the tubes. ("Meets or exceeds OEM" my a$$.)
Old Dec 20, 2022
BrotatoChip's Avatar
Super Moderator
re: Odd spark plug tube seals [solved]
It sounds like you're talking about the valve cover seals/nuts and not the spark plug tube seals. The rubber and top ring come together as one part number. Item 14 in the below pic. Part number 90441-PNA-010. There are six holding the valve cover on.
Old Dec 20, 2022
Nope. I mean the tube seals.
Old Dec 20, 2022
do you have pics? Or a good explanation of what you are talking about? We can't see them from here
Old Dec 20, 2022
Super Moderator
The spark plug tube seals fit into the underside of the valve cover, item 4 in the picture. Part number 12342-PCX-004. I'm not really following your description at all so a picture would be helpful.
Old Dec 20, 2022
Will get pic. The "odd" thing is that the cover doesn't and won't receive the tube seal in your pic. It takes some other wacky $#!7.
Old Dec 20, 2022
Ok. I think I figured it out. The weird flange that I never see anywhere else is what's left of the old seals that, while not leaking, were totally brittle and disintegrated rather than be removed.
Old Dec 21, 2022
Super Moderator
Re: Odd spark plug tube seals
You are correct.
lindylex
Jun 20, 2019 12:44 PM
evanpienaar
Feb 10, 2018 10:03 AM
2002-Civic-DX
Jun 26, 2014 07:23 PM
TomKi
Jun 20, 2014 10:10 PM
