Sponsored by:
Sponsored by: CARiD
Need help with spark plug tube seals
Old Jun 20, 2014
TomKi's Avatar
TomKi is an unknown quantity at this point
The car is a Honda Civic EX with a D17A2 engine. The upper spark plug tube seals that came in my Felpro kit did not come with the steel rings. Does anyone know a part number for a seal that comes with a steel ring?
Old Jun 20, 2014
GolNat's Avatar
Prelude Owner
Re: Need help with spark plug tube seals
Part #6 is all you need. What steel ring?
http://www.hondaautomotiveparts.com/...DER+HEAD+COVER
Old Jun 20, 2014
lowlife9's Avatar
ninja edit i think he's talking about the valve cover washers???
Old Jun 20, 2014
cja3455's Avatar
cja3455 is an unknown quantity at this point
part#6 has something like a steel ring embedded inside the rubber, OEM seals are always better then any other seal
Old Jun 20, 2014
TomKi's Avatar
It fits in the recess in the valve cover just under the hole for the spark plug and the top of the spark plug tube slides through it. There are two versions of part #6. Do one or both have some kind of stiffener so that they will stay put in that recess? The old ones had steel rings inside them, thin pieces of sheet metal. When I wanted to change them I didn't realize that the replacements weren't going to cut it.
Old Jun 20, 2014
cja3455's Avatar
yes the one selling for 2.03$ has it
Old Jun 20, 2014
TomKi's Avatar
Thank you very much. That should do the job.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
hayden55
Jul 2, 2015 06:12 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
MikeyBoy
Jan 26, 2002 06:45 AM
