won’t go past 4k in 4th gear
Old Jan 16, 2023
chinD17VQ35's Avatar
chinD17VQ35 is an unknown quantity at this point
bought an 03 ex auto last month, and took it on the highway for the first time. turns out i can’t accelerate past 4k in forth gear. looked around old forums and the most common problem I saw users link it to was a bad ECM causing it to go limp. but it doesn’t flash the check engine on and off like limp normally does. any ideas?
Old Jan 17, 2023
Re: won’t go past 4k in 4th gear
is the light on or not?
so only in 4th gear? is it revving above when in other gears?
about ECU, check if the alternator bolts are loose or not
Old Jan 17, 2023
BrotatoChip's Avatar
Super Moderator
My guess, fault code for VTEC which causes limp mode. Engine limited to 4k at all times.
Old Jan 17, 2023
CEL lights on but only for an evap code. yes, it revs about 4k in other gears. i’ll check the alternator tonight. thank you g🫡
Old Jan 17, 2023
i thought so as well, but no code for anything like that. from what i’ve gathered, when it goes into limp mode it should b bumpin the rpm at idle up n down, but it ain’t¿ idk man. imma obd it again tn n c if any new codes popped up. thank you bro🗿
Old Jan 17, 2023
Super Moderator
Limp mode would have no affect on idle. I would guarantee there is another fault code, likely related to VTEC.
kpiz00ex
Mar 3, 2012 09:16 PM
bluejy
Jul 15, 2011 05:41 PM
ashleighx0
Apr 10, 2010 09:10 AM
trev0006
Mar 31, 2006 01:17 AM
CrazyCanuck
Nov 7, 2004 07:36 AM
