Cylinder Head Assembly Replamcement
Old Nov 10, 2021
oscar32101's Avatar
oscar32101 is an unknown quantity at this point
Hello All,
this is my first post on the forum and I have a question regarding cylinder head replacement. I have a high mileage civic (2005 Honda Civic Ex D17A2 1.7L AT(nothing special) )
I’m having to do the head gasket and I’ve been enjoying working on this car so now I want to do a rebuild. I’m down to the head gasket and I’m wondering as to if I buy a rebuilt cylinder head assembly online, if I will have to do something special in regards to timing it. When I removed my current cylinder head assembly I simply marked on the belt with whiteout. If I bought a new one will I not be able to simply replace?
Thanks so much!
Old Nov 10, 2021
FRSam's Avatar
Click Here
Re: Cylinder Head Assembly Replamcement
I’d just take your head to a machine shop. Unless the engine overheated, it should be fine.
Are you planning on reusing the timing belt?
Old Nov 10, 2021
https://www.civicforums.com/forums/1...ne-timing.html
https://www.civicforums.com/forums/1...t-diy-2-a.html
Old Nov 10, 2021
oscar32101's Avatar
thanks for the reply, I did water pump and timing belt a month before so I’ll reuse it. And thanks for the machine shop tip
Old Nov 10, 2021
oscar32101's Avatar
thanks
bachands
May 26, 2021 03:18 PM
Palmetto77
Aug 21, 2015 09:22 PM
gmcuajo
Mar 22, 2006 05:33 PM
Kevdroz
Jul 23, 2003 02:30 PM
