Help me find correct motor please
Old Apr 18, 2022
Donman123's Avatar
Donman123 is an unknown quantity at this point
Blown 2002 LX
I need to buy a cheap used motor, and diy swap.
If I buy an eBay motor... What is the right motor? And will I need to change anything?
ECU? It's automatic transmission.
Do I have to flash anything?
I'm wanting to simply pull bad motor... Then drop in good motor. Turn it over and go?
Please help
Old Apr 19, 2022
Re: Help me find correct motor please
LX uses the D17A1.
D17A2 is for the EX model, engine have VTEC. D17A is the JDM engine (Japan rakes the taxes for older cars, so most change cars earlier than other countries)
A and A2 work as well, just the VTEC will not activate, since ECU is not programmed to use VTEC.
Old Apr 19, 2022
Donman123's Avatar
ThanksSo no other stuff, as far as changes I'll have to make?
Old Apr 19, 2022
it's a drop in
if you get a D17A/A2, you will not have the connector for the VTEC in the car.
The VTEC in these engines works as:
Low load/RPM, it slightly opens one exhaust valve
higher RPM/Loads, it will fully open that last valve
so, without VTEC activating, the engine will struggle more at higher loads/RPM to breathe - might be slower than the original A1 engine
but should work.
changing the ECU to VTEC and wiring it will be a lot of work, TBH, with the antitheft keys, programming, etc.
so, if you can find a A1 engine, that's the easiest and more straight forward, if not get a A/A2, just know it might be slower
Old Apr 19, 2022
Donman123's Avatar
Thanks guys.
a machanic just checked the VIN.
He says it's a v6 in it.
Old Apr 19, 2022
Colin42's Avatar
Your mechanic is dead wrong. These cars never came with a v6
Old Apr 19, 2022
FRSam's Avatar
Click Here
No civic has ever come with a V6 in it. I’m not sure what’s going on here.
Old Apr 19, 2022
BrotatoChip's Avatar
Super Moderator
I'm convinced you do not have a Civic. When we see LXI, we assumed you meant LX which is a valid Civic trim.
Old Apr 19, 2022
Colin42's Avatar
I figured he missed a space "...LX I need..."
Old Apr 19, 2022
the only LXI i see is the 80's accord, but it was another 4 bangers, not 6
I also think it was a space missing there.
change mechanic, no one need a VIN number to tell if it is a 4 inline or a V6
Old Apr 19, 2022
FRSam's Avatar
Click Here
An edit was made.
My money's on it being an Accord LX V6, or something is just wayyyyyyyyyyyyyyyyyy off here
Old Apr 19, 2022
Donman123, if it's a civic, recommendations still stand
if it is a non-civic, you need to find a different forum.
If it is a civic and you mechanic said it is a v6, change mechanic...
Old Apr 19, 2022
all others, calm down. misspelling should not be a fatal error (exception to threads saying "My breaks are not working" - well, if they are breaks, they are supposed to be broken, now if you are talking about brakes, that's a different story)
and if mechanic said it's a v6 civic, it's not OP's fault
compu2
Sep 20, 2017 10:01 AM
briannbii
Sep 21, 2012 11:28 AM
civic01lx
Buy, Sell, & Trade - Archive
Dec 16, 2008 11:15 AM
dubbc
Jan 11, 2006 08:15 PM
Island2K2
Dec 30, 2003 04:17 PM
