Crank But No Start - High Miles
When I went to start my '01 LX recently, the engine fired for perhaps a half second then spun without firing. I removed the oil-fill cap and had the wife turn the key so that I could see if I had valvetrain movement. I do.
Just did a compression test on two cylinders and both have around 90 psi. I know that 90 psi isn't optimal but the engine has approximately 230K. It had a timing belt installed at 130K.
Wondering if perhaps the belt has jumped out of time but not sufficiently as to bend a valve. Certainly a bent valve would yield near zero compression.
I've yet to remove the front cover to check belt condition or check timing marks.
Re: Crank But No Start - High Miles
I can smell fuel. It rattles as though trying to start indicating spark. Comp test was just me plugging in the gauge and spinning it after it's been sitting for a couple of weeks.
Does the front cover have to be removed to check mech. timing? Does the cam cover have to be removed?
Thanks for the reply, btw.
I would actually check for spark.
the upper half of the timing cover has to come off, you can loosen or remove the valve cover
Ariah J. Davis
Jul 20, 2015 07:15 AM
heath3000
Jun 27, 2015 10:30 PM
The Hammer28
Jan 30, 2012 02:06 AM
lilhuff
Nov 18, 2011 06:11 AM
