Power loss after timing belt jump
Old Feb 18, 2016
Hillel's Avatar
Hillel is an unknown quantity at this point
I recently was driving my 02 Civic EX VTEC and when I punched it to accelerate the engine stalled. Pulled over and tried to start: Crank -> start -> stall consistently. It turns out my timing belt had jumped... Not sure how many teeth. I replaced the belt with a new tensioner pulley (from the dealer). That fixed that, but upon driving there is significant power loss and unusual sound at higher RPMS. The car idles fine and is drivable, but very poor acceleration and I suspect I have valve damage. I just did a compression test and these are the results:
Compression test
1- : 157psi
2- : 152psi
3- : 166psi
4- : 177psi
So, the obvious question is now what? Cylinder 4 seems normal, but cylinder 2 is way off from that. Anyone know the "acceptable" range specs? Do I need a valve job? Thanks!
Old Mar 27, 2016
danilo1's Avatar
danilo1 is an unknown quantity at this point
Re: Power loss after timing belt jump
Fair chance you have bent a (?) valves. Noise being the giveaway. Comp pressures are odd but in passable range for a 'tired/worn' motor
Sooo.. IF you want to fix this..you DO need to either replace or rebuild your Cyl head.
curaze
Sep 22, 2015 08:27 AM
deanaZoom
35
Sep 19, 2015 12:22 PM
stank
Sep 16, 2015 07:40 AM
MamaBear2015
Sep 15, 2015 09:35 PM
Markias
Detailing
Nov 4, 2001 05:15 PM
