radiator coolant fan switch
Old Jan 12, 2022
Wtrowbri's Avatar
Wtrowbri is an unknown quantity at this point
I have a 2005 Honda Civic
I have replaced the radiator,radiator cap,thermostat and fan switch sensor and temp sensor.
My problem is when I replaced the fan sensor switch everything was working fine drove it to work, the next day when I turned the key the fan came on I replaced the fan switch sensor again and worked fine again drove to work and the next day turned key and fan came on again what would cause the fan switch sensor to not to work again ,do I have something shorting the fan switch sensor out.I am running out of Ideas any help with solving this problem would really help thanks.
Old Jan 12, 2022
BrotatoChip's Avatar
Super Moderator
Re: radiator coolant fan switch
Are they super cheap aftermarket replacements?
Disconnect the switch, check continuity across the two pins. Do you have it?
Old Jan 13, 2022
Wtrowbri's Avatar
They are the duralast sensor $32.00 not sure if that was the cheap ones and I do have continuity on both the sensors the old one and the new one they work until the car has run for a while then they just burn out.
Old Jan 13, 2022
then the issue could be the wiring
Old Jan 13, 2022
Wtrowbri's Avatar
form where to where the fuse box to the sensor or in the harness itself ?
Old Jan 13, 2022
could be different from car to car, they all lived different lives... Start measuring at the fuse box?
91LXdriver
May 12, 2016 08:05 PM
raziel22
Dec 2, 2013 09:14 PM
95EX
Jul 12, 2010 07:44 AM
04 Honda Civic
Mar 20, 2010 02:11 PM
Killzone2142
Aug 21, 2008 12:41 AM
