1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
cooling fan
Old May 10, 2016
91LXdriver's Avatar
91LXdriver is an unknown quantity at this point
cooling fan
I have a 91 civic lx 1.5 l auto, is it normal for the cooling fan to come on every time I switch on the ignition, cold or hot,, dont even have to start the car, just switch it on,,
Old May 10, 2016
Re: cooling fan
You mean that radiator fan runs all the time the key is on?
Not normal.
It should only run when needed, when the coolant temperature is high enough to trip the thermal switch for the fan.
Someone probably hotwired it to run like that because they couldn't figure out how to make it work the right way.
Or did you mean the condensor fan? (if it has AC)
Old May 10, 2016
91LXdriver's Avatar
Re: cooling fan
radiator cooling fan, could the thermal switch be stuck?
Old May 10, 2016
Re: cooling fan
"Could be."
There's a whole lot of 'could be'....until you figure out what's actually causing it.
Locate said switch and unplug it. Does the fan quit?
Old May 12, 2016
91LXdriver's Avatar
Re: cooling fan
LOL, cant find the thermal switch, not on thermostat housing, any ideas?
Old May 12, 2016
Re: cooling fan
Back of block, two pin thermoswitch next to the oil filter about 10 oclock position
Old May 12, 2016
91LXdriver's Avatar
Re: cooling fan
thnx, thought that was oil sending unit
Old May 12, 2016
Re: cooling fan
Oil sender should be right there in the same area too. Straight above the oil filter?
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
Buttertopwhite
Nov 17, 2015 06:41 PM
Doc
Dec 12, 2001 11:47 AM
colombianDXcivic
Bolt-on Engine Performance
Nov 25, 2001 09:38 PM
808specifxz
Nov 17, 2001 10:39 PM
