Civic ignition stuck!
Today when I started my 1992 civic si hatch the car started fine but when I went to push the clutch it sounded like the starter would start, even though the car was already on. When I would release the clutch the noise would stop. I then noticed that the ignition would not turn in any direction. After the car was running for about 15 minutes I saw that the temp gauge was at full hot, I panicked and Disconnected the ignition fuse to shut the car off. If anyone has info on what happened and how to fix it would be greatly appreciated. Thanks
Re: Civic ignition stuck!
...sounds like a few things.
maybe your clutch position switch is now connected to the starter (positive wires worn out and touching)?
If you don't know how to trouble shoot I'd take her to a mechanic.
Just wondering how that could be the issue of the key tumbler doesn't move at all and is stuck in the ignition spot. I'm guessing I just need a new tumbler?
If the key won't turn, fix that first.
IDK if you can take it apart and figure out what happened or if you just buy another unit, depends on your abilities
Once that works again, see if the starter still works right or if it was damaged
Then see if it still overheats and why.
(Make sure the radiator is full of coolant and the fans work first)
Anticrosswalk
Jul 21, 2015 01:37 PM
roger t
Jun 22, 2015 07:25 PM
bluedoggy1
Jun 20, 2015 11:25 PM
petesdodgyhonda
Jun 19, 2015 09:04 PM
