1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Bad luck dropped bolt into trans
Old Nov 20, 2015
Trunks's Avatar
Trunks is an unknown quantity at this point
I dropped the distributor bolt into where the trans fork meets the slave cylinder. How bad is it?
Old Nov 20, 2015
Re: Bad luck dropped bolt into trans
Why is the rubber cover missing?
How bad is it?
I vote BAD and it needs to come out.
Old Nov 20, 2015
Trunks's Avatar
Yea it actually fell inside inside. There is a slot in there for some reason.
Old Nov 21, 2015
Mad Dog Tannen's Avatar
Try a magnet!
Old Nov 23, 2015
OptimisticWay's Avatar
OptimisticWay is an unknown quantity at this point
Remove the dust shield for the flywheel cover. Try to get at it there if after a magnet and/or a little 3 arm parts grabber doesn't work. Like the tool Cohagen used to remove the transmitter from his nasal passage. It looks painful but it's not. Much like your experience will be removing the dropped bolt.
rollaguy
Suspension
Nov 11, 2015 07:48 PM
cgriffin51
Oct 31, 2015 03:43 PM
Egrich
Transmission
Oct 31, 2015 12:47 AM
nooby7
Oct 17, 2015 03:10 AM
