7th gen , P0722 honda part numbers
2005 civic lx 1.7l A/T sedan
I need to replacereplaces for code P0722
What are the part numbers for the input and output speed sensors so that I may purchase.
Any assistance in other solutions to get my car going again would be appreciated
Thanks
Thanks
Re: 7th gen , P0722 honda part numbers
Is the countershaft speed sensor installed correctly?
Check the resistance of the sensor for failure.
Check for a short to ground in the circuit from the sensor connector and the PCM terminals.
Check for loose fitting connectors at the PCM or open in the wires.
