Help with timing, installing cylinder head on the block
Good morning,
I am changing my head gasket, in the process, I also decided to change my piston ring.
- I had my cylinder head rebuilt at the machine shop
- I cleaned my engine block and installed new piston rings.
Now I am ready to reinstall my cylinder head on the block, But I am a little confused about the timing of the valves and piston.
How should I adjust my camshaft and crankshaft for cylinder head installation?
Any guide or advice is appreciated.
thank you
pgeorge
thank you
pgeorge
Re: Help with timing, installing cylinder head on the block
gmcuajo
Mar 22, 2006 05:33 PM
