Slight ticking sound - at idle and under throttle...
Old Jun 22, 2022
jhomes551's Avatar
jhomes551 is an unknown quantity at this point
2005 EX 4D
298,000 miles
Any idea what I should check related to this sound? Is this a normal sound?
Civic has been sitting for about a month, finally replaced both belts. Engine ticking was present before belt job - FYI.
Checked oil level - good. Not sure what else to check for this issue?
Injectors? Assuming maybe from direct inject, sound just seems more prominent than in the past.
The AC compressor is shot, not sure if that is the noise either?
Thanks in advance...
File Type: mov
Old Jun 22, 2022
Re: Slight ticking sound - at idle and under throttle...
not injectors, too loud.
have you adjusted valve lash? (too loud, but just in case)
Old Jun 22, 2022
jhomes551's Avatar
I have not adjusted valve lash!
Old Jun 22, 2022
Colin42's Avatar
Check the valves
Old Jun 24, 2022
FRSam's Avatar
Click Here
The most likely culprit is definitely valve lash, but it’s one of those things. At 300k miles, it’s not going to sound like a brand new engine.
IfollowUdie
21
Jul 22, 2021 01:10 PM
EJ1_94
Nov 8, 2012 02:14 AM
mooncake2
Nov 15, 2005 07:48 PM
Zigen1
Oct 10, 2003 05:43 AM
ohiojosh78
16
Feb 27, 2003 08:08 AM
