Cranium
Old Jan 10, 2023
Cranium1814's Avatar
Cranium1814 is an unknown quantity at this point
Cranium
I have a 2003 civic that I just replaced the motor in and am having a couple of small issues first off my idle wont kick off high idle and is staying at a constant 2000 rpms this is a new issue as it never did this before the motor swap . Second I am getting a code p0132 I know this is an O2 sensor however I just replaced the cat converter and am wondering if I should replace this sensor or will this issue straighten itself out in time .
Old Jan 10, 2023
Re: Cranium
what is a cranium problem?
Old Jan 10, 2023
Colin42's Avatar
Re: Cranium
Please edit your thread title to accurately reflect what your problem is. What brand are the parts you replaced?
Old Jan 10, 2023
Re: high idle and p1032 engine code
So a cranium problem is one that wont go away , as for what parts l have l ordered a cat converter from an exhaust company in Ontario .
Old Jan 10, 2023
Colin42's Avatar
Re: Cranium
If you need to get an o2 get a denso. Try cleaning the iac. Or disconnect the battery for half an hour and reconnect
Old Jan 11, 2023
BrotatoChip's Avatar
Super Moderator
Re: Cranium
Check for vacuum leaks as well.
Old Jan 11, 2023
Re: Cranium
his username, my dude.
VCSMaster
Jun 25, 2021 09:22 AM
batchhack99
Oct 9, 2020 03:25 PM
2005ex
Idle Issues
37
Aug 2, 2019 11:43 PM
Philip54
Dec 26, 2017 10:37 PM
Darlea
Dec 14, 2011 06:24 AM
