Knocking / ticking noise around timing cover
Old Sep 2, 2021
zatu's Avatar
zatu is an unknown quantity at this point
Recently replaced the cam shaft position sensor last week. Car ran great until last night. I got off the freeway and walked outside the car, noticed that there was a strange noise under the hood.
Thought it might have been the harmonic balancer, but the bolts are tight and there is no play.
Took the valve cover off and timing cover off. Timing belt is still tight and the crank position sensor is still in place, with no movement from the bolt.
What could this noise be???
Old Sep 2, 2021
FRSam's Avatar
Click Here
Re: Knocking / ticking noise around timing cover
Did you put the Woodruff key back in properly?
Old Sep 2, 2021
zatu's Avatar
the pulley was not removed. I used a 19mm socket to make sure the bolt was on tight and it was..
I'm thinking this might be the timing belt tensioner?
Old Sep 2, 2021
Good lord shut it off before it jumps time, or worse
Remove upper timing and see if the spring for the tensioner pulley is disconnected/missing/damaged
The tensioner pulley arm could now have a slot cut all the way through the steel, instead of a round hole or reinforced hole, where the hook on the end of the spring was attached
Old Sep 2, 2021
some of the belts are moving more than the direction they are intended to...
Old Sep 2, 2021
zatu's Avatar
i dont have the tools to remove the crankshaft pulley so i cant see the spring's condition.
last night, while moving the power steering hose to see the pulleys, the noise died down a little but was still present..
i just noticed this also when i replayed it in slow motion.
Could this be rod knock? I youtube'd some other videos and the sound doesn't sound exactly the same, but I'm really worried...
Old Sep 2, 2021
first solve the checking the tensioner.
Then you start looking for other things.
Old Sep 3, 2021
Oh, sorry.
Remove the upper timing COVER.
Old Sep 4, 2021
zatu's Avatar
Oh, sorry.
I took the cover off and couldn't see well enough to check the spring's condition
I'm thinking it could be some plastic that got cut off from the old Crankshaft Position Sensor.. A little chunk of it was missing and probably shot around the timing covers and harmed something.
Hauled the car over to the mechanic. I'll report back with that they find
Old Sep 6, 2021
after removing the upper timing cover, it's not hard to see the installed spring if you know where its supposed to be.
If it was not found still stretched between the anchor pin and the tensioner pulley, that's trouble.....the loose belt slapping and loose pulley makes a lot of noise and may allow timing belt to skip teeth/bent valves is very possible
Old Sep 7, 2021
zatu's Avatar
the timing belt was on tight. no slack when I pressed/pulled it after removing the upper timing cover
Mechanic says that he thinks it's rod knock and has to do a engine swap.
Labor alone, 12 hrs, gonna run $1500...IDK what he's gonna charge for the new engine + parts
Old Sep 8, 2021
BrotatoChip's Avatar
Super Moderator
Drain the oil to see if there are metal flakes present (rod bearing destroying itself). That would just about confirm rod knock.
Philharmonic
Jul 12, 2021 09:43 AM
sankewl
Aug 14, 2017 08:33 PM
contevo
117
Dec 3, 2015 01:29 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
jtuck13
Feb 15, 2015 02:48 PM
