Oil leak
Old Oct 16, 2021
Camdawg's Avatar
Camdawg is an unknown quantity at this point
Oil leak
Oil leaking onto transmission 03 civic ex
also hits lymp mode at about 4,000 rpm won’t hit VTEC pleasseee help!!!
Old Oct 16, 2021
FRSam's Avatar
Click Here
Re: Oil leak
Limp mode is probably engaging because you’re oil level is low. Post some pics so we can help better. First guesses would either be can seal or valve cover gasket.
Old Oct 16, 2021
Colin42's Avatar
Re: Oil leak
Or the VTEC valve
Old Oct 17, 2021
Camdawg's Avatar
Re: Oil leak
Just did the valve cover casket, spark plugs, front main seal all new belts new water pump and will post more pics
Old Oct 17, 2021
Re: Oil leak
if recent, should be easy to spot where the oil leak is coming from, unless you did not clean the engine while at the job
HondieBondie
Apr 1, 2021 12:36 PM
Steevo
Oct 28, 2011 09:38 AM
Polski Dan
Nov 19, 2010 10:16 AM
civic2000abc
Jul 31, 2010 10:13 PM
fi dx
Engine Swaps
Feb 23, 2005 11:33 PM
